Gas Gauge Issues...HELP!!
Ok, so a few months ago I replace the fuel sending unit. Clipped the gas gauge wire at the fuel sending unit back on the post, everything worked fine. This weekend I replaced the seal on the sending unit, reclipped the wire on the post and the gauge reads Empty, when I pull it off gauge goes to Full and stays there. Check at the fuse box to make sure it's plugged in properly, it is, checked both ends for corrosion, everything fine there. Any ideas??? Have not had time to take sending unit out but don't know why the problem would be internal since everything worked fine before simply replacing the rubber seal. Thanks for the help.
Re: Gas Gauge Issues...HELP!!
Check the float- may be hung up on side of the tank.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
Did you check to see if the tanks empty?
