Old 02-21-2010, 04:23 AM   #1
jbristo67
resident oilfield trash
jbristo67's Avatar
Need a favor from one of you factory big block guys
I need one of you guys to measure from the front of your block to the radiator. I am trying to figure out clearances for my serpentine system. Thanks in advance guys
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 02-21-2010, 12:10 PM   #2
clay68c10
clay68c10's Avatar
Re: Need a favor from one of you factory big block guys
I've got about 10.5" from the rad surface to the water pump mating surface.
I unloaded a stock 89 BBC serp setup I was going to use because of the lack of space.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 02-21-2010, 04:30 PM   #3
combustion
i jave a gen 5 big block. i also used the gen 5 serpentine. its a tight fit but it fits really good. this is retaining the mech fan. idk if that helps much
If it`s 3.73 ratio you will spint the wheel 100 times to the driveshaft`s 373 times.Or,if you`re lazy,you could just spin the wheel once and the driveshaft will spin 3.73 times.Or, 3 and 3/4 turns.And if you`re real lazy,I can sell you a tab for whatever ratio you want.
Or,you could read all the suggestions and try those.It`s been well explained,I think,already.
combustion is offline   Reply With Quote
Old 02-21-2010, 05:44 PM   #4
clay68c10
clay68c10's Avatar
On my setup with the motor in the stock location, there was no room for the '89 mechanical fan, I think there was less than 1" of room between the waterpump hub and the rad. It would have been tight for a dual electric fan. In hindsight, I wish I would have kept it and maybe shifted the motor back an inch or so, or found a dual fan that would work.
13 Tahoe LTZ
