Old 02-24-2010, 06:55 PM   #1
66coffin
66coffin's Avatar
Question anyone put a 73-87 12 bolt in a 64-66?
i'm getting ready to put a '74 12 bolt in my '66 c20, my truck has t-arms and coils, the 12 bolt is for leaf springs. i'm thinking of buying one of the kits with a adj. track arm and tube mounts. are there other ways to do it using what i have (c20 pan hard, orig. rear end etc.) or are the kits the best way? any help or ideas from you who have done this would be great. pics too.
'66 c10ish straight 292 power!
66coffin is offline   Reply With Quote
Old 02-24-2010, 08:01 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: anyone put a 73-87 12 bolt in a 64-66?
I put a 77 model rear into my 64. I just bought the saddles from ECE and used their Super Track Bar.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 02-28-2010, 04:09 AM   #3
66coffin
66coffin's Avatar
what's the best way to center it up so i know where to weld on the saddles? how do i figure out the pinion angle as my truck will be much lower than it sits now?
Old 03-01-2010, 01:20 AM   #4
Captainfab
60-66 Nut
To center the rear end, just measure the same distance from say the backing plates to the saddles. For the pinion angle you want the pinion to be at the same angle as the trans output shaft at ride height.
Old 03-02-2010, 11:39 PM   #5
66coffin
66coffin's Avatar
the angle should be the same regardless of the height of the rear end? so i should determine the exact angle of the trans shaft and duplicate the angle on the rear, is that right?
Old 03-03-2010, 02:33 AM   #6
Captainfab
60-66 Nut
The angle will change somewhat at different heights due to the trailing arms. Yes measure the exact angle of the trans output and make the pinion the same at ride height.
