Cultural Infidel
![]() Join Date: Jan 2007
Replacing rear coils
I'm going to replace my rear coils and would like step by step instructions. Any help is greatly appreciated.
posted via La-Z-Boy -Mark 1972 C-10 Fleetside 350/TH350 PS PB A/C Cab Sadly....Sold ![]() 1968 Short Fleet 350/TH400 PS PB Delivered by Fine69 ![]() ![]() It may be that your whole purpose in life is simply to serve as a warning to others. A man is not complete until he is married -- then he is finished. |
sharp as a marble
Re: Replacing rear coils
It is pretty straight forward, actually. You need to get rear of the truck jacked up, and have jack stands under the frame rails in front of the rear end. Then do one spring R&R at a time. There is a long bolt that runs through the coil spring, at the top and bottom of the spring. The tough part, IMO, is getting those 40 yr old bolts to come loose. If you have an 1/2 air gun, it will be a big help, but even with that they might not come loose.
Jack up the rear end just until it move up a bit. This will compress the coil spring. Get the bolts out, and the slowly let the jack down until you can remove the spring. Put the new spring in and reverse the procedure. Rear springs are not like fronts, in respect to how much the springs are compressed. Go slowly, pay attention, make sure that the jack stands are stable. HAVE FUN! Last edited by cparman; 02-24-2010 at 07:17 PM. |
Cultural Infidel
Thank you.
Fun isn't what comes to mind when dealing with old bolts and heated springs.
sharp as a marble
NOW, you have already got a bad attitude about the fun you will have!!! Dirt is my younger brother, and this repair/fun stuff, is all what you make it.
Do you have a torch available? Do you have a lift available? Makes this a ton easier. It is really not that bad, if you have a friend that will help you. I replaced my OE springs a few months ago, and we had my truck up on a lift, and a box end wrench, 1/2 impact, a little bit of skin, and WA LA!!!! The damned spring almost mashed my big toe. On the right foot, the left foot is already FUBAR, and I did not need any more trama to it. If you do not have a torch available, I might suggest that you soak the bolts with PB BLASTER, a day our so before the big event. I am 54 yrs old, and STILL get excited when I think thru a project, and it turns out like I wanted to. I will tell you though, I ALWAYS have a plan B. Meaning that I have thought about what might happen that I cannot control I LIKE A PLAN B PLAN ! pm me if you have a question |
Cultural Infidel
I'm 49, will be doing this alone, in my driveway, no torch, no friends.
![]() I do have a shiny new impact wrench! Of course it will be fun, when I'm finished. I am a big believer of planning and plan "b"s. As soon as this rain passes I'll get to work.
Mark, I to live in clearwater, that means you got a friend you don't even know about. I do construction work for a living. I can rebuild a sbc1 with confidence and supension work doesn't scare me so if you want some help let me know.
CHEVY/GMC VIN DECODERS Last edited by bruceman1968; 02-25-2010 at 04:26 PM. |
Coordinator of Synchronicity
![]() Join Date: Dec 2005
See thats what this site is all about bringing people and trucks together
![]() See you got friends in Clearwater. Good luck guys.
Rick 1971 Suburban ... W.I.P. Build Thread Customization is ones personal touch-- not what other people think it should be Last edited by Burb; 02-25-2010 at 11:45 AM. |
Maybe a day or two before you start, spray the bolts a couple times with penetrating oil. You might also have a four foot cheater bar and a can of spinach available!
Good Luck!
![]() 383 Stroker - Edlebrock Air Gap intake and 670 CFM Holley Street Avenger carb. Hooker Comp Headers w/ X-Pipe and 2.25 duals TKO-500 & 3.08:1 rear I Love HEMI's, they're soft & chewy! ![]() |
Heres a little better info on easy wasy... the EASY button.. LOL
jack stand the frame like mentioned. High enough that you can get an impact wrench under the trailing arm. put a jack under the pumpkin or whatever side you are removing first. Jack it up to relieve a little pressure and remove the bottom bolt. Then lower the rear end and youll have more room to get to the top bolt! repeat for the other side. |
![]() Join Date: Jul 2009
I am a rookie at working on these trucks, so my approach might be completely wrong. I was able to get the lower bolts loose without much effort. The upper bolts were not going to move, they were rusted together. I went and picked up a 4 and ½ inch grinder and a few flapper disc’s. (The disc’s run about $6 at Home Depot). Using the grinder, I just ground the head off the upper bolt and punched it through the frame. Once the bolt was punched into the frame, it was easy to get the remains out of the frame. Again I am a rookie, it took about 45 minutes to get the first upper bolt out and about 15 minutes to get the second upper bolt out on the other side of the truck. I replaced the bolts with grade 8 bolts I picked up at the local Ace Hardware.
Craig |
#11 | |
#12 | |
dazed and confused
members met: redbaron69, billsbowtie,nc67 |
#13 | |
You first try to take it off, bust a knuckle. Strip the head, bust another knuckle. Heat it up, start a fire. You get the picture.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
All the bolts I have to 'remove' up here in the MidWest means get the cut off wheel ready-
#15 | |
sharp as a marble
I like it!! And the soak the bolts for a few days
#16 | |
Wear some safety glasses/goggles, too... rust and dirt falling in the eyes, and filthy hands don't play well with each other... I used Deep Creep on all the fasteners a half hour or so beforehand (while I changed my oil, and some other things...), and a 1/2" breaker bar, to get them started, then switched to a rachet, and took my time... The really fun part is if, or when, you replace the front springs... I tried to do them by myself... came apart no problem.. trying to put them back in, eh, not so much... You'll need a vict, er I mean friend to assist in that one... At least I did... Relax, take your time... It's nasty, not exactly easy, but hey, you're workin on your truck... Getting things done... Have fun! Last edited by I_FLY_LOW; 03-02-2010 at 10:14 AM. |
#17 |
Cultural Infidel
Thanks for all the info. Springs are replaced, no rust in my eyes and no skinned knuckles. The bottom bolts came out easily. The top bolts twisted in half.
The new springs have a 4" drop. The old springs had been heated. Why people heat and ruin there coils I will never understand.
