Old 02-24-2010, 07:47 PM   #1
Gene
Gene's Avatar
How do I remove cab trim?
The trim piece that is right below the rear window, I can't see a way to remove it without damaging it. Any ideas?
Gene is offline   Reply With Quote
Old 02-24-2010, 08:09 PM   #2
mbgmike
Re: How do I remove cab trim?
It can be tricky. Its held on by small plastic clips. I start in the center and start to pry it up with a tiny screw driver and slide it till I hit a clip. THen slowly twist it to pop it off. We sell a tool but a screw driver works. Keep sliding it down doing the same. Its stainless so it is a little tough
picture is a similiar clip not actual
mbgmike is offline   Reply With Quote
Old 02-24-2010, 08:14 PM   #3
tim21391
tim21391's Avatar
i didnt use any tools on mine.. i just got my fingers behind it and ran my fingers down it and it all popped off
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 02-24-2010, 09:48 PM   #4
tcb-1
Nothing to see here.....
tcb-1's Avatar
I'm with Tim. fingernails and a little work. if you break the clips, they are plastic and dirt cheap....
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
