Old 03-04-2010, 03:30 PM   #1
Deficit Spending
Deficit Spending's Avatar
Changing to 5 lug drums?
I recently got DM310's '66 SWB. He has already done a ton of work, now it's time for me to finish things up. He kept the stock rear end, had the axles drilled for 5x5, installed the lugs, now I need to put on new drums. I tried a '73 drum, but the hole where the axle is supposed to fit is too small on the drum. I then went to buy '71-'72 drums, because I thought they were 5 lugs, but that doesn't appear to be correct. Should I take the '71-'72 drums and have them cut for the 5 lug, or get the '73 and on, and have the middle hole machined?
Deficit Spending is offline   Reply With Quote
Old 03-04-2010, 03:37 PM   #2
shortbed70
shortbed70's Avatar
Re: Changing to 5 lug drums?
71-72 drums are 5 lug if there for a half ton truck. If there not 5 lug take the drums back and get the correct ones or machine the center of the later 70's drums center hub bigger.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 03-04-2010, 04:10 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
You can get the deep backing plates from GM and go with the wider pads in rear, also. The drums should be availble at a local parts store. I dont know all the particulars, but this is a nice upgrade.
I'm with S/B70......the drums you picked up should work. 71-72 are 5-lug.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-04-2010, 05:28 PM   #4
Deficit Spending
OK, update. This is a 12 bolt rear, does this matter?
Old 03-04-2010, 05:11 PM   #5
Deficit Spending
Well I'll try again. The local parts stores, Kragen, and Autozone, show 5 lug, but I won't know until I order then, again, if the hole for the axle is correct. I'm not sure these guys know what going on? But then I'm not doing much better.
Old 03-04-2010, 05:28 PM   #6
aggie91
I'm just glad to be here!
aggie91's Avatar
I am not 100% sure about this, but I think that the hub register on the axle for the 6 lug axle is 3.56". The newer (71 up) 5 lug axle may have a smaller diameter register on the axle. 6 lug drums were still available on the 71 up for the 4 wheel drive trucks...
If you redrilled the stock axles, I am not sure that a stock 5 lug drum will work without machining the center of the drum larger to fit the axle or machining the hub register down to fit the drum. It has been WAY to long since I did this, but I believe that I machined the axle's heb register down to fit the 71-72 drums...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-04-2010, 05:32 PM   #7
Deficit Spending
You are right about the hub centers being the issue. It seems I can buy 6 lug w/the proper hub size, and have them machined for 5 lug, or go w/the 5 lug, and have the center machined bigger, which I think might be easier, and nicer.
