03-04-2010, 10:42 PM | #1 |
Justified!
Pypes Exhaust Installation/Review
OK, if you saw my other thread, I bought the Pypes Violator Exhaust system from Summit. It is supposed to be for C10 pickups 64-72 I believe, and will fit longbeds as well as shortbed trucks.....
Kind of a long thread, plus there are 2 video's of before and after..... First, I ordered the system on Tuesday from Summit. I get home Wednesday, and her is what I find waiting for me....
Chad 1964 GMC Fleetside Shortbed....350/700R4 tranny |
03-04-2010, 10:43 PM | #2 |
Justified!
Re: Pypes Exhaust Installation/Review
So I open the box and take inventory just like they say to.....
everythings there....
03-04-2010, 10:45 PM | #3 |
Justified!
They recommend laying out the exhaust on the floor and putting it all together to make sure it fits and that there are no problems.....
All the pipes are slip fit, and slide together fairly easily.....They are labeled, but the labels do not match the installation sheet..... My new x-pipe The shiny new SS Violators.......NICE!!!
03-04-2010, 10:47 PM | #4 |
Justified!
They recommend you jack the truck up and start from the back.....telling you to center the x-pipe, and then run out from there.........ehh, I ended up starting from the front, running the pipes from the headers to the x-pipe, and then working on installing the mufflers.....
03-04-2010, 10:50 PM | #5 |
Justified!
After getting the muffler and the x-pipe installed on the drivers side, I look around and realize I lost some clamps.....Then I read the instruction sheet. They only give you 8 clamps for the whole system..........I was thinking you need maybe 12....it would have been nice.....
Plus the sheet was very vague about which joints you actually clamped, and which you left just fit together...... Muffler with the hanging strap attached....
03-04-2010, 10:51 PM | #6 |
Justified!
Then I got to the part about installing the pipe over the rear axle......You have to trim this to length......No problem I got that done......then you attach the tailpipe they provide.......
Nope, I do not like how this looks.....
03-04-2010, 10:54 PM | #7 |
Justified!
So I finally got the entire exhaust minus the tailpipes installed.......and cranked it up.....
Sounded pretty good..... I will be having some pipes either re-bent or new ones made for my truck.... All in all, it sit under the truck, and looks pretty good for the most part. I will be MIG welding the joints this weekend, so I really did not need the clamps, but I still think they should include more, especially with all the joints you have and with what you pay for the kit..... here is how it looks from the side..... another....
03-04-2010, 11:00 PM | #8 |
Justified!
The old mufflers Youtube video....
The new mufflers.....
03-04-2010, 11:05 PM | #9 |
Justified!
All by myself!! In about 2-3 hours.....I started at 4:00 went and got dinner, then finished around 7:30 or so...........
Having a helper would have been great, but my son, Dad, and the few friend that would answer my phone call were busy.........yeah right........
03-05-2010, 12:31 AM | #10 |
Rollin' Old Skool
nice work & write-up...sounds pretty good...what made you decide to go with the Pypes system?
oh, where in N. Bama are you? |
03-05-2010, 01:29 AM | #11 |
Sounds good
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=346597 https://www.facebook.com/pages/198-C...1434001?ref=hl |
03-05-2010, 08:17 PM | #12 | |
Justified!
I just wanted a kit so I could install it myself. Plus, everyone runs Flowmasters it seems, and i thought I would break off the beaten path..... I am located in Huntsville......
03-05-2010, 01:50 AM | #13 |
nice! Sounds pretty good.
If you get a chance, I'd like to hear a vid of it outside as well. |
03-05-2010, 02:28 AM | #14 |
60-66 Nut
That sounds pretty good. I agree that it might be better sound quality outside. If you were to turn the mufflers verticle as per the instructions, the tail pipes would be a little higher. But I do like the mufflers horizontal better also. Could you raise the mufflers a bit, or would the pipes hit the crossmember? That would raise the tail pipes some also.
Thanks for taking the time to do this review. This is something we can all benefit from.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 03-05-2010 at 02:30 AM. |
03-05-2010, 09:49 AM | #15 |
Senior Enthusiast
Great thread. Thanks for taking the time to record the upgrade and posting for everyones benefit.
03-05-2010, 10:23 AM | #16 |
One foot in front of the other
Yes, thanks and nice work.
03-05-2010, 11:29 AM | #17 |
maybe you shouild call Pypes and tell them of your experience so they can make some changes. If we don't tell them they will not know and they do like our input. http://www.pypesexhaust.com/
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 03-05-2010 at 11:31 AM. |
03-05-2010, 01:33 PM | #18 |
Resistance is Futile
Nice job on the review. I can't tell a lot of difference between the 2 systems; alot of frequencies bouncing around the garage. Seems the whole system is very low (as far as ground clearance), too.
You didnt mention if you had headers or manifolds. Just curious.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
03-05-2010, 04:36 PM | #19 | |
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
03-05-2010, 08:23 PM | #20 |
Justified!
I can't raise it up any more, it is almost hitting the driveshaft crossmember.....
I have full length headers, so they come to the bottom of the frame rail......I had thought about getting shortys, but since I am not going any lower, they will be fine.. I will try to get a video of it outside, but it will be tomorrow....I've been busy working on plumbing under the house...... Thanks, Chad
03-06-2010, 01:34 AM | #21 |
Oh thats always fun...
03-06-2010, 07:37 PM | #22 |
Justified!
OK here is an outside vid of the truck running with the new mufflers....
I will be raising them up probably about 2 inches at least to get the maximum clearance I can.... Please ignore the wiring mess under the dash.....I'm still cleaning up the wiring and working on the light switch......And where I placed the camera....I propped it up on my sons mustang......
03-06-2010, 07:37 PM | #23 |
Justified!
I also raised my timing a little bit after that vid....while the cam-like rumble sounds good, it really did not run that great.....So it sounds a little smoother now....
It really doesn't sound that loud in person, my computer speakers must be horrible.....
Chad 1964 GMC Fleetside Shortbed....350/700R4 tranny Last edited by 64GMCHorsepower; 03-06-2010 at 07:39 PM. |
