Old 03-05-2010, 04:47 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
Starter troubles
The other night, I tried to start my truck (after a conciderable amount of driving) and it just barley bumped the motor once and stopped. I had a friend jump me and it started right up perfectly on one little bump of the key. I had the battery tested and they said that it had 100% charge. Today, I tried to started and it did the same thing. could it be a bad soleniod? What do yall think?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 03-05-2010, 04:50 PM   #2
rogergodding
rogergodding's Avatar
Re: Starter troubles
Sounds like heat soak.... are you running headers?
rogergodding is offline   Reply With Quote
Old 03-05-2010, 04:51 PM   #3
rogergodding
I see you are running headers from your sig. The solenoid/starter are probably just getting too hot.
Old 03-05-2010, 05:04 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
sounds like heat soak to me too. Anything you do now is just a bandaid, time for a new starter, and maybe a heatshield.
A lotta people say the mini starters aren't effected by the heat, may want to try that route.
Old 03-05-2010, 05:06 PM   #5
rogergodding
skip white mini on ebay $85!! I have the red one.
Old 03-05-2010, 05:21 PM   #6
1-PU70
1-PU70's Avatar
Its time for a Ford solenoid. I switched to one years ago and put all my starting problems behide me.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 03-05-2010, 05:40 PM   #7
68gmsee
Active Member
68gmsee's Avatar
It's either a bad solenoid or the starter itself.
Some things that go bad on these starters is the copper washer inside the solenoid gets pitted and burnt and won't make proper contact. The symptom is just a clicking sound when the solenoid picks. On some starters you can dismantle the back of the solenoind and flip the washer. Or you can sand it smooth. But best is to buy a new one for around $25 or less.
The other thing is the bearings will wear out and the armature will rub on the windings causing a hard start or no start at all. Best is to replace the starter.
The other thing is burned wires and as mentioned above heat soaking. Too much heat causes resistance that prevents the starter from turning. A new starter will eventually act up. Use heat sheilds or mini starter.
68gmsee is offline   Reply With Quote
Old 03-05-2010, 05:45 PM   #8
Wrenchbender Ret
Take the starter off & take it apart. If it is not burned up clean it up & put in new brushes if needed. Replace the selinoid & put a shield over it. These arn't that hard to work on yourself & they are strong & dependable. PU has a great sugestion. Useing a Ford type selinoid as a relay does away with the voltage drop from the harness & can solve a lot of problems.
Wrenchbender Ret is offline   Reply With Quote
Old 03-05-2010, 06:37 PM   #9
Sinister
Between Trucks...
Sinister's Avatar
F@rd solenoid here solved my hot start problems.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 03-05-2010, 07:27 PM   #10
VetteVet
Msgt USAF Ret
VetteVet's Avatar
'This is the best way to wire it IMO.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 03-05-2010, 11:41 PM   #11
pat 70/71
pat 70/71's Avatar
hey, just a thought, check your battery cables could have a little corrosion on the ground side/ positive side (cheep fix)? hope this helps, Pat
pat 70/71 is offline   Reply With Quote
Old 03-06-2010, 09:52 PM   #12
crm318
crm318's Avatar
Well it seems that it was time for a new battery. I got a new one and it has fixed everything.
1972 Cheyenne
