03-06-2010, 01:53 AM | #1 |
20s or 20-18 combo
what size backspace and tiresize would I need to get the tire tucked look in a 20 inch tires size? I tried doing a search but everywhere i look it say do a search. I would also be willing to buy a good set. thanks. Oh yea its a 67 with 6 lugs. thanks
03-06-2010, 02:02 AM | #2 |
motor exploder
Re: 20s or 20-18 combo
What did you search for? You say 'tucked' but what drop are you talking about? Static drop, laying frame w/ bags? How wide a wheel are you wanting to run?
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
03-06-2010, 02:36 AM | #3 |
I was just thinking 6 inch spring drop in the rear, and around 4 inch drop in the front. I was just wondering what size wheels and tires I could run without narrowing or tubbing the rear, or doing any major body work to slightly tuck some 20s, or 20s in the rear and 18s in the front. Im talking just were the tire verly tucks in the fender. If anyone has any pics of what im talking about with there size, or some for sale would be great. thanks
03-06-2010, 02:48 AM | #4 |
Shake and Bake!
Well, first off Welcome to the forums! And as far as what size tire you can run, is more going to depend on your wheel offset/backspacing, width etc. If you are going with a 18x8 or 8.5 in the front I have seen guys run from 4" to 5" +/- backspacing.
The rear is not really as big of an issue, as long as you don't run huge backspacing. I have seen a lot of guys running 255 to 285 series tires without problems depending on the wheel and offset. There is a ton of different ways you can go with wheels, backspacing, widths, staggering etc and a lot of guys on here have some very nice setups, I'm sure they will chime in. I would start with finding a wheel you like in a matching 6 lug pattern and see what diameters, widths, and backspacing they offer it in.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent." Thomas Jefferson "You are remembered for the rules you break." General Douglas MacArthur "Support Our Troops And The NRA" Last edited by Leviticus; 03-06-2010 at 02:48 AM. |
03-06-2010, 10:27 AM | #5 |
Tot Roddin'
IMO... the largest set of tires I would consider running would be either a 245 or 255/40-20 up front and a 295/40-20 in the rear. Anything larger than that will require an exact BS requirement for your application.
I'm not much on a staggered combo, so I would either do 18's or 20's but I'm am just one of many different opinions. 6-lug wheels are in short supply for these trucks unless you don't mind having a 6-spoke design, but most prefer a 5-spoke design. With a 4/6" drop you will not have an issue running a 20x8 or 20x8.5 in the front matched with a 20x10 in the rear. You need to consider your suspension setup before you ever consider ordering wheels. Since you're wanting to go with a 4/6 drop you will need to convert to disc brakes up front which will widen your track in the front (changing your BS requirements).
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
03-06-2010, 01:30 PM | #6 |
Here's what I have
72 5 lug rearend with 20x10, 5.75" back spacing with 315/35/20. The tires are within about 1/16" of the inner wheel wells when fully dumped on the front I have 20x8.5 with 4.25" b.s. with 255/40/20. I have CPP modular drop spindles that move the front wheels in a little . At full dump with my alignment, the tires touch a little on the inner fenders. Ideally I'd run less back spacing. |
03-06-2010, 07:16 PM | #7 | |
03-06-2010, 02:03 PM | #8 |
good info guys thanks, Im thinking about disc brakes up front 20 by 10 in the rear, and 20 by 8 1/2.
03-06-2010, 06:52 PM | #9 |
would I have to run disc brakes up front for fitment issues or safety issues. If I if have to convert to disc brakes I might as well, convert to five lug for more wheel options right. What would be the ideal lug patern if i was going to convert?
03-07-2010, 01:05 AM | #10 |
motor exploder
5x5 is the truck and fullsize (impala/caprice) bolt pattern, and pretty common. Another is 5x4.75, which is the S10, Camaro/Firebird and Corvette pattern. The majority of people use the 5x5, and so do many of the disc brake conversion kits.
