Old 03-07-2010, 01:54 AM   #1
63 extreme low
63 extreme low's Avatar
72 axles in my 63
Can I use 72 axle shafts in my 63 rear end housing? Are they longer than the stock ones? Any cheap options?
1963 Big Back window short fleet
63 extreme low is offline   Reply With Quote
Old 03-07-2010, 01:58 AM   #2
Captainfab
60-66 Nut
Re: 72 axles in my 63
No they won't work. 1) the '72 axles are 3/4" too long 2) the '72 axles are 30 spline and the '63 axles are 17 spline. Cheap options depend on your skills or if you have to pay someone to do the work, but plugging and re-drilling the axle flanges might be the less expensive option. You'll also need the '71-'74,'75 brake drums.
Old 03-07-2010, 02:46 AM   #3
63 extreme low
CPP sells spider gears for the five lug swap, whats that about?
Old 03-08-2010, 12:52 AM   #4
Captainfab
60-66 Nut
Those are 30 spline side spiders to replace the 17 spline spiders in the '63 & '64 rear ends when converting to 5 x 5 axles.
Old 03-07-2010, 04:51 AM   #5
burlapen
burlapen's Avatar
I am running 72 axles in my 63 housing. I also changed out the 3rd member to the 72 as well. Basically I setup the 72 third member in the 63 housing and didnt realize the spline count was different until I went to put the 6 lug axles back in...so I just ran the 5 lug axles from the 72. I never noticed a length difference but I didnt check that closely. It ran this way for probably 6 months with no problems.
63 Chevy C-10
My build thread
burlapen is offline   Reply With Quote
Old 03-07-2010, 10:40 AM   #6
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
! Curious. Doesn't the bearing ride on a shoulder on the axle (i.e., the axle IS the inner race) and how would the brake drums cover the shoes? I guess maybe the wider drums from the newer axles are masking the mis-match and the machined shoulder is wide enough (I seem to remember it is) for the bearing to still ride on it.
Larry
fleetsidelarry is offline   Reply With Quote
Old 03-08-2010, 12:55 AM   #7
Captainfab
60-66 Nut
I don't doubt that this went together, but I seriously doubt that everything is correct since the axles themselves are 3/4" longer.
Old 03-08-2010, 01:48 PM   #8
burlapen
burlapen's Avatar
I went out to the garage for some further investigation
The drum does appear to stick out a bit, but I cant tell if the shoe is riding entirely on the drum or not. More of a concern is obviously if the correct part of the axle is riding on the bearing. I took some pics.
63 Chevy C-10
My build thread
Old 03-08-2010, 01:51 PM   #9
burlapen
burlapen's Avatar
The 63 axles had this shield which the 72 did not have
63 Chevy C-10
My build thread
Old 03-08-2010, 04:02 PM   #10
63 extreme low
My axles didn't have that shield. I just got a whole 72 leaf spring axle, guess I will put that in.
Old 03-07-2010, 08:02 AM   #11
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
They're definitely longer axles.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-09-2010, 03:37 AM   #12
63 extreme low
thanks for all the feedback guys!
Old 03-09-2010, 03:48 AM   #13
63 extreme low
So Captainfab you make and sell parts AND you are a fountain of knowledge too. DAMN OVERACHIEVER !!! Thanks again, by the way installed the disc brackets on the 68 camaro they fit great!
