Old 03-08-2010, 11:08 AM   #1
onebadbowtie
onebadbowtie's Avatar
01 Silverado Problems
Recently my heater/ac controls have been messing up. when i turn the temperature adjuster to cold it still blows hot air. I have tried every setting to see if i can get it to work and i got nothing. everything else works just fine though. Whats wrong with my controls? Do i need a new control unit?
Also the horn quit working recently so i checked the fuses and they are good. Next and i went to the salvage yard and got 2 working horns and put them on and they still dont work what should i check next?
Thanks James
James
94' Chevy K1500 Extended Cab 4x4 5.7
72' Chevy LWB K10, 350, SM465, NP205 Project "Daily Driver"
onebadbowtie is offline   Reply With Quote
Old 03-08-2010, 02:55 PM   #2
CrazyJesster
CrazyJesster's Avatar
Re: 01 Silverado Problems
i also had horn trouble with mine i repalced the horns relay and fuse. didnt seem to fix anything so i got an airhorn setup. never found a soulution i also have an 01. the controls im not too sure about i havnt had that problem yet.
Project 82 ReBoRn http://67-72chevytrucks.com/vboard/s...d.php?t=441842
CrazyJesster is offline   Reply With Quote
Old 03-08-2010, 06:09 PM   #3
Gray Ghost
Gray Ghost's Avatar
Could be the heat/AC blend door malfunctioning....I've heard of that happening before.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 03-10-2010, 02:00 AM   #4
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
I'd check to see if vacuum is getting to the control panel. I had a 97 cavalier that the vacuum line broke in the engine compartment and it had the same probs you mentioned.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 03-10-2010, 09:31 AM   #5
onebadbowtie
I have found that if you select the temperature you want before you turn on the key then it works so what do you guys think now?
thanks for the responses
James
James
Old 03-10-2010, 03:09 PM   #6
MattA
MattA's Avatar
Horns short out frequently. Usually the lower one and often caused by water intrusion. If you replaced the horns you probably still have a bad fuse. Its in the underhood fuse block.
A/C problem is probably the temp door actuator. Its just to the right of the trans hump on the bottom of the a/c case. Often they will start clicking before they fail. The control head goes bad on them also so its a bit of a crap shoot without actually checking it out with a scan tool.
Try disconecting the battery for a few minutes. The actuators will resynchronize after loss of voltage. Sometimes this will bring them back.
MattA is offline   Reply With Quote
Old 03-10-2010, 03:19 PM   #7
onebadbowtie
ive checked the fuses and they are all good.
as for the heater i will try unhooking the battery and see if that does it. if not my brother has 99 gmc and im going to pull out his controller and try it in my truck and see if that fixes it. what kind of scan tool would i need to check this? and would the heater controls even through a code if it was messing up?
thanks James
James
