03-09-2010, 10:32 PM | #1 |
dose not get gas when i go to start it
i have a in line fule pump blazer tank my probalem is that i have to bleed the line just before the presure regulater and fule filter to get the fule pump to push the fule up to the carb every time i start it it will befine after that for the day but the next time i go to start it the fule pump wont push it tell i bleed the line agin any have an idea whats worng
64 buick skylark 65 buick skylark 67 chevy 2wd Lb 68 2w Lb 05 chevy colbalt |
03-09-2010, 11:18 PM | #2 |
The Older Generation
Re: dose not get gas when i go to start it
Where is your fuel pump located? I sounds like the fuel is siphoning back into the tank when the truck sets for very long. LockDoc
03-10-2010, 12:29 AM | #3 |
its in the frame
03-10-2010, 12:59 AM | #4 |
I would guess one or all of your rubber lines is old and or rotted. That would let it pull air into the line and loose its pumping ability.
New rubber lines and new clamps might fix it. Dennis |
03-10-2010, 01:39 AM | #5 |
Front, back, middle? There is a lot of frame there. I would locate it as close to the tank as possible. LockDoc
03-10-2010, 01:43 AM | #6 |
Do you have your tank vented?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
03-10-2010, 12:08 PM | #7 |
tank is vented all new lines its at the lowest part of the frame at the back by the tank
03-10-2010, 12:12 PM | #8 |
i should all so mention that it was working fine tell i ran out of gas
03-10-2010, 12:17 PM | #9 | |
If you ran it out of gas and left the electric pump running, you could have easily ruined the inside of the pump. Electric pumps are cooled/lubricated by the fuel flowing through them. Another thought would be to put a check valve in the line behind the fuel pump to prevent fuel from flowing back to the tank. These can be restrictive, so you may want to get a large one and use some fittings to step the size back down to 3/8 or whatever size fuel line you are using.
1970 C20 LWB Fleetside with a 472 Caddy engine! TH400 Restoration in progress 07 Yamaha 650 V-Star Custom 83 Honda V-45 Magna |
03-10-2010, 11:34 PM | #10 |
Hybrid67
If I'm not mistaken, I had an elec fuel pump inline that had a built in device to prevent backflow as part of its design. Also, it seems that the vacuum created between the sending unit "dipstick" being immersed and the fuel pump should cause the gas to be stagnant. Think of it like a straw. If you suck the water through it and keep it in your mouth, the water will stay in the straw. Same principle. Also, running the pump dry would toast the seal inside because of the fuel regulating the temp in the pump like the previous post said and cause it to not hold back the fuel. Not sure where it would get the air in the line to cause it to siphon though, something in the line/tank would have to introduce air to start the vacuum process in the other direction generate a vacuum . But then again, I'm no scientist, just a guess. I'm curious to see how this one comes out. Good luck
Keep em' Running! All show.....no go |
03-16-2010, 07:09 PM | #11 |
well got it fixed after checking the line and finding no losses or leaking conetion i checked the fule filter it seamed to be good i was talking with my pa and he said to check the return line so i checked the return on the fule filter it had no flow though the return part put a new one on and now it works great thanks for all of your help
03-16-2010, 07:32 PM | #12 |
i love the mechanical pumps
