Old 03-10-2010, 12:22 AM   #1
78BO
78BO's Avatar
Throwing PS belt.
Well guys, some of you might remember I had issues with my alternator belt coming off but I fixed that with an aftermarket bracket. I also fixed the gas and installed my stall converter. Everything was running fine. But now all of a sudden I've started throwing my pw steering belt............
I don't get it. I've never had that problem. And so far it only happens when I'm rolling and turn it until it locks (stops). When I started it in the garage I turned it back and forth right to left (lock to lock) and nothing happens. Yet I drove it down the road went to turn around and the dang thing chirped and the belt came off. I can't figure it out. When I have my son turn the wheel so I can see why it's doing it the dang thing wont throw it.
What do you thing?
1978 Chevy C10 Bonanza, 405hp/440tq 383, tweeked Th350.
http://www.facebook.com/#/profile.ph...&id=1116781152
78BO is offline   Reply With Quote
Old 03-10-2010, 01:07 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Throwing PS belt.
If it chirps prior to being thrown, the power steering pump is locking up at full turn.
How is the alignment?
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 03-10-2010, 01:21 AM   #3
78BO
78BO's Avatar
I had it aligned at NTB a few month ago. Maybe I'll take it back. I pay for the 3 year plan. But that doesn't really fit because it wont do it sitting still.
Old 03-10-2010, 02:10 AM   #4
gchemist
gchemist's Avatar
I meant belt alignment.
I would not trust NTB to align your truck. I only take my vehicles to a place on Congress and Oltorf. They aligned my truck perfect. Runs straight as an arrow. They even added a little for performance driving.
Besides, some shops won't even touch my truck. Shops who would try, couldn't get it up on their lift!! The a-arms are too low.
Old 03-10-2010, 03:16 AM   #5
Oldschool82
Balls to the wall!
Oldschool82's Avatar
Make sure your crank pulley bolts are tight too. I just threw my p/s belt a couple of weeks ago and after looking closer, noticed my pulley wobbling a little.Two of the three small bolts had backed out. All that was holding it on was the one small bolt and the larger center bolt and they had begun to loosen. Probably not your problem, but one thing you could check.
1982 swb 1/2 ton
Also have a 2001, 400+ Hp T-top Camaro SS
Loving my old Chevy truck and my new square body family on here!Thanks for all the help,tips and ideas I have gotten already guys.
http://67-72chevytrucks.com/vboard/s...d.php?t=388836
............_________{\___
............l_(0),,,______(0)l
Oldschool82 is offline   Reply With Quote
Old 03-10-2010, 07:56 AM   #6
78BO
78BO's Avatar
That's a good suggestion. I'm gona go check it now.
Old 03-10-2010, 01:28 AM   #7
spinem
haha, ford guys...
im assuming youve checked the obvious...
allighnment of pullys,.... belt is tensioned /w/ pry bar (good and tight)
spinem is offline   Reply With Quote
Old 03-10-2010, 07:54 AM   #8
78BO
78BO's Avatar
Well, as for the alignment, they are off a little. But they've been like that for a while. I've got around 3000+ miles on it and it just started doing this.
