Old 03-10-2010, 07:36 PM   #1
jyaughn
jyaughn's Avatar
bagges on a 62
how do you bag the front of a 62 pick up with torsion bars in the front?
jyaughn is offline   Reply With Quote
Old 03-10-2010, 08:13 PM   #2
1LoC10
Insert Title Here
1LoC10's Avatar
Re: bagges on a 62
I would assume you would have to lose the bars.. and plate and cup the control arms
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 03-10-2010, 08:17 PM   #3
jbjburbs
jbjburbs's Avatar
Re: bagges on a 62
lose the bars and mount a shockwave or something similar??
That's what is recommended for 2002 Tahoe and the have torsion bars..
John J
Bodied 1994 Suburban on custom frame -
http://67-72chevytrucks.com/vboard/s...d.php?t=672297
Dad's 1948 Suburban -
http://67-72chevytrucks.com/vboard/s...d.php?t=563150
Bagged 1995 Suburban - SOLD
Bodied 1995 Tahoe -SOLD
jbjburbs is offline   Reply With Quote
Old 03-10-2010, 09:11 PM   #4
62 Bowtie
62 Bowtie's Avatar
Re: bagges on a 62
Yeah I'd like to know too. So I could just remove the T-Bars and use the original A-ARMS, weld in plates and install bags or... install shockwaves in the original shock location?
62 Bowtie is offline   Reply With Quote
Old 03-10-2010, 09:25 PM   #5
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
Re: bagges on a 62
I don't know why not, I mean, torsion bars aren't some mysterious alien technology. They're just springs. If there's enough room between the a-arms for bags, then you (and maybe I) should be able to do this like we would a coil-spring model.
Larry
fleetsidelarry is offline   Reply With Quote
Old 03-10-2010, 10:22 PM   #6
protrash64
Resistance is Futile
protrash64's Avatar
Re: bagges on a 62
My friend bagged his '62 they way you describe. Removed torsions from the a-arms and then just plated and sandwiched a bag in there. He had a machine shop press the rods out, FYI.
I would not use shockwaves to support your truck off of shock mounts; they are not made for the load.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-10-2010, 09:04 PM   #7
jyaughn
jyaughn's Avatar
Re: bagges on a 62
what is a shockwave
Old 03-12-2010, 08:09 AM   #8
jbjburbs
jbjburbs's Avatar
Re: bagges on a 62
shockwaves are an airbag with a shock inside the bag. Basically an all-in-one install for trucks with torsion bars...if you're bagging anything and aren't familiar with some of the parts and pieces i would spend sometime on ridetech.com..
shockwaves are sold for 2000-2006ish tahoes and suburbans using the stock shock mounts to support the truck. I would think that they can handle the load otherwise they wouldn't sell them (tons of street rods run shockwaves).
I don't know about 62 setup, but if it's already running a shock the shockwave would be a much easier install and not mess with the geometry as much as just welding a plate to the arms. I would guess you could add support to your stock shock mounts if you're worried about it, but i'm assuming they're stronger than you think. It's not like bagged truck is going to do much off roading...
John J
Old 03-12-2010, 08:43 AM   #9
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: bagges on a 62
Get a Dropmember.
Nate makes his front Dropmembers for the torsion bar trucks also.
You get a mustang rack for steering, a ton of extra ground clearance, and bags, of course.
The second picture appears to be ride height.
Look here for his products:
http://porterbuiltstreetrods.com/site/
Keith
Convert to disc brakes.
Old 03-12-2010, 08:23 PM   #10
62 Bowtie
62 Bowtie's Avatar
Re: bagges on a 62
Get a Dropmember.
I don't see any torsion bars in that pic
Old 03-12-2010, 11:47 PM   #11
lolife99
lolife99's Avatar
Re: bagges on a 62
Exactly!
The Dropmember allows you to modify your torsionbar frame and use stock 73-87 a-arm or aftermarket tubular a-arms.
I don't think any other company offers air ride suspension products specifically for the 60-62 chassis.
Just Porterbuilt Street Rods.
Keith
Old 03-12-2010, 09:47 AM   #12
jyaughn
jyaughn's Avatar
Re: bagges on a 62
i want to keep mine as original as i can. and plus i dont have the money for all these drop members and stuff like that. the only reason i am bagging it is cause i already have the stuff from another project
Old 03-12-2010, 09:48 PM   #13
jyaughn
jyaughn's Avatar
Re: bagges on a 62
when you bag it you take the torsion bars off and the bags are like springs
