Old 03-10-2010, 08:45 PM   #1
dgaskins21
Auto conversion from 3 speed saginaw
If I took an th350 off a 70's to early 80's truck what all would I need to do to get the bell housing tranny and drive shaft to fit my 68 C10 250cui?
Any help would be appreciated.
Thanks Dan
dgaskins21 is offline   Reply With Quote
Old 03-10-2010, 08:58 PM   #2
davepl
davepl's Avatar
Re: Auto conversion from 3 speed saginaw
The Chevy bellhousing bolt pattern has been standard since at -least- 1955, maybe before that.
You'd need a flexplate that matches your starter (same number of teeth as your current flywheel, unless your starter is modern enough to handle both).
You'd need the converter for the TH350.
You'll need some kind of shifter, either a column and linkage from an auto truck or you could use a cable-driven floor mount shifter.
Sorry, don't know the difference in lengths.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 03-10-2010, 09:00 PM   #3
culp7
HickTown
culp7's Avatar
just my $.02 but i'd keep the 3-speed, they are getting harder and harder to find everyday and i personally love the uniqueness
1993 Ford Mustang Vert w/ 2.3
1969 Chevy C/10 w/350
1968 Chevy C-20 w/250
1976 Dodge Aspen W/ 225
2000 Toyota Tundra w/4.7
1987 Dodge Ram D-100 w/360
255/70-15
___________
(oo)══╬══(oo)
culp7 is offline   Reply With Quote
Old 03-10-2010, 09:53 PM   #4
dgaskins21
Are you stating that a th350 will bolt to my current bell housing?
And all I need is to match up the starter teeth to the flex plate? Also a torque converter a cross member and a drive shaft?
Old 03-10-2010, 10:05 PM   #5
capev86
my 72 burb has the saginaw and i'm keeping it. gonna put a 406sbc in front of it and hopefully add the OD unit that was available. personally, if i was going to the trouble of changing over, i'd get a 200-4r or 700-r4 for the overdrive. the 350 is a good trans, but it sounds like you are losing the "fun factor" and not gaining any advantages, unless you do a lot of towing....which i plan to do with my truck with the saginaw.
capev86 is offline   Reply With Quote
Old 03-10-2010, 10:55 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The TH350 has a built in bellhousing. You will need to remove your existing trans and it's bellhousing.
You will need to swap starter nosecones or buy a different starter too. Your current starter bolts to the bellhousing with 3 bolts. The automatic trans does not have this provision and the starter is therefore bolted to the block with two bolts. The nosecones interchange if you like to keep your current starter and avoid buying another whole starter instead.
You will need the auto trans flexplate (flywheel).
You will need to remove the existing trans crossmember (it's riveted into place) and install an auto trans type of crossmember beneath the tail of the auto trans.
Need shifter and cooler for trans.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-10-2010, 11:25 PM   #7
dgaskins21
If I could find a 700-R4 I would use it. My next question is about the drive shaft. Is there a difference in length or can I just bolt on the drive shaft I get with the new auto?
Old 03-17-2010, 03:41 AM   #8
dgaskins21
I went ahead and did a floor shifter conversion for my 3 speed works great I need to find a better frame though mine is rotted out in the rear cab is in great shape for a northern truck all repairable and so is the dog house thanks for all the help guys
