![]() Join Date: Apr 2008
CPP rear springs
I remember a while back people were saying the cpp rear springs were too soft and were bottoming out.Do they still have this problem?I am about to order the lowering kit for my truck and only want to do this once.I am plaining on going with 2.5 drop spindles,1 inch front springs and either 4 or 5 inch rear springs.I dont want to c notch my frame,will I be ok a with 5 inch drop in the rear?
Restoration Virgin!
Re: CPP rear springs
Might want to get the adjustable track bar and shock relocators....
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
If you drop the rear that far the track bar will bind and you will have a bear of a time with shocks. There are several places where you can get an adjustable track bar, track bar relocator and shock mount relocation kit that will allow your rear suspension to work correctly with the shorter springs. CPP has the right pieces as does Early Classic Enterprises.
I was planning on getting the shock relocator and adj. track bar.I was just wondering about the spring quality/stiffness.I want to make sure I dont bottom out over bumps.
I'm in the same boat. But I'm also looking at doing their bolt-in c-notch.
But I see they have the springs in regular drop version, but also drop HD... I was assuming those would be too rough though, since I'd rarely be hauling a load and never towing with this truck... |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I have run quite a few sets of Early Classic 6 inch springs on my different trucks over the years. They are sufficiently stiff to still haul. I hauled Honda Goldwings in the bed of my 72 stepside several times with no undue bottoming out. They did bottom occasionally with the bike in the bed, but not enough to be annoying or justify c-notching the truck. Unloaded, no bottoming issues at all.
I can't speak of CPP springs with any first hand experience.
69 Fleetside
![]() Join Date: Mar 2009
just get the heavy duty 4" springs they sell and some 1" drop blocks...
I bought the 4" drop standard duty CPP springs and they are WAY too soft in my opinion. I just replaced them with the 4" drop heavy duty CPP springs and I am MUCH happier with these.
Here are a couple of pics to give you a little visual difference in the springs.
#10 | |
hmmm.... Just curious, did you put them on a long bed, or short bed? Gas tank relocated to the back frame? And how did you decide they were too soft? I know this can be kind of a personal opinion, but did you have excessive bottoming or something?
get it! |
Long bed and the tank was not relocated yet.
You're right, this is very much a personal preference thing that's why I said they were too soft in my opinion. ![]() I weight just shy of 180 and I could stand in the back of my truck and the rear end was on the bump stops, and yes that is with the proper shocks, etc. When I would hit a bump at about 30, the rear would hit the bump stops. I'm just not a fan of that soft of a spring. |
#12 | |
Those top springs look just like Jeep Wrangler Rear Coils to me. also this gave me some great info as I am about to do this with my truck in the rear. as I just did a full frame swap from leafs to coils. |
Thanks,I didnt know they offered Heavy duty springs.
69 Fleetside
only in 2" and 4" drops though...so if you want lower you need to add some blocks
#15 |
BOHICA
How low can you go before you need a new track bar and relocate the shocks?
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig! |
#16 |
69 Fleetside
I'm going with the 4" HD's and hoping I don't have to do either, but we shall see...
#17 |
![]() Join Date: Oct 2008
My 72 short bed is currently tore down for rebuild, but when it was together and a 4 inch drop springs in the rear suspension I took some measurements of shock and suspension travel. I just posted a shock relocation picture I generated that you might want to take a look at to help determine how much you would like to drop your aft suspension (post # 257) http://67-72chevytrucks.com/vboard/s...318544&page=11
From my understanding I have soft springs and plan on using air shocks to compensate for carrying loads. From my calculations any drop more than 4 inch springs will almost be sitting on the rubber frame stops. And the use of drop blocks to get additional drop you might have to be concerned with scraping the shock relocater with a flat tire. So with any thing more than 4 inch drop other considerations will need to be considered. I haven’t taken any measurement to see if there’s any interference with the bed floor or any other components but you might be able to gain an additional ½ inch suspension travel by taking a ½ inch off the frame rubber stop (just a thought).
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544 |
