Old 03-11-2010, 01:27 PM   #1
Farmstore34
Farmstore34's Avatar
Question Degreasing
Hi all,
I am replacing the clutch on my K20, and I would really like to clean off the tranny and transfer case before putting them back in. They are covered with the thickest, nastiest grease and crud probably dating back to 1972. The standard engine degreaser and a garden hose is just not cutting it. Any tips?
Thanks,
Colby.
Farmstore34 is offline   Reply With Quote
Old 03-11-2010, 01:30 PM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Degreasing
some oven cleaner from the dollar store.... buy a few cans spray it down heavily, let it set in the sun for a few hours then hose it off with high pressure.... of course scrapping with a putty knife first will help if as thick as you state.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 03-11-2010, 01:34 PM   #3
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
Re: Degreasing
Take a couple of hours with a plastic putty knife and a wire brush before the liquids come out. Make sure you're on a tarp or gravel though; that crap is like glue on a concrete surface.
Once I had the trans pretty well scraped, I did 409 and a toothbrush to get it ready for paint.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 03-11-2010, 04:21 PM   #4
D-Rat
D-Rat's Avatar
Re: Degreasing
x2 with oven cleaner and a pressure washer.
let the oven cleaner sit on there a bit to penetrate.
Simple green works good to finish up with.
1970 CST with a screaming 400
www.nissan4wheelers.com
D-Rat is offline   Reply With Quote
Old 03-11-2010, 05:24 PM   #5
OhOneWS6
OhOneWS6's Avatar
Re: Degreasing
I've had much better results with easy off extra strength over cleaner than the cheap off brand stuff. Might buy one can of the good stuff and test it for yourself.
OhOneWS6 is offline   Reply With Quote
Old 03-11-2010, 08:06 PM   #6
primetime
primetime's Avatar
Re: Degreasing
maybe a pressure washer
1968 Chevy C10 swb fleetside
2005 Chevy Silverado crew cab (SS)
1977 Goldwing cafe racer
1977 Chevy nova (first car/ first love)
primetime is offline   Reply With Quote
Old 03-11-2010, 08:14 PM   #7
DPowers
One foot in front of the other
DPowers's Avatar
Re: Degreasing
Hot water pressure washer is the ticket.
DPowers is offline   Reply With Quote
Old 03-11-2010, 08:30 PM   #8
ole red
Re: Degreasing
I took mine to my favoriate car wash. It was nasty getting up under there and sprayen it but it cleaned it up purty good. Go to a good car wash because some car washes do not have enough presure to p.
69 stepside, 1/2ton, 4X4, 350/350/205
ole red is offline   Reply With Quote
Old 03-11-2010, 10:14 PM   #9
Beatcoaster
69 Fleetside
Beatcoaster's Avatar
Re: Degreasing
be careful with over cleaner on aluminum...it started to eat at the finish on my starter really quick...but did an amazing job of degreasing and after a couple treatments while leaving it on only 10 minutes at a time and a green scouring pad, my engine bay was super shiney!!
Beatcoaster is offline   Reply With Quote
Old 03-11-2010, 11:03 PM   #10
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: Degreasing
Does oven cleaner work better than Gunk?
Tom Vogel is offline   Reply With Quote
Old 03-12-2010, 12:17 AM   #11
OhOneWS6
OhOneWS6's Avatar
Re: Degreasing
The brand name over cleaner worked better than gunk for me. The off brand worked about the same as gunk.
Old 03-12-2010, 02:02 AM   #12
Beatcoaster
69 Fleetside
Re: Degreasing
Agreed, brand name oven cleaner worked way better than gunk for me as well...
Old 03-11-2010, 11:10 PM   #13
mr48chev
mr48chev's Avatar
Re: Degreasing
I've had good luck with Oil Eater. You can find it at parts houses and sometimes at Costco. After you scrape the heavy stuff off spray it on, let it set for a few minutes and wash it off at the car wash or sometimes with a hose. It works great for grease spots on cement floors too. Some of the shops up here are using it in their hot tanks instead of caustic as it is biodegradable.
Old 03-11-2010, 11:30 PM   #14
leddzepp
Moderator
leddzepp's Avatar
Re: Degreasing
If you can remove the part, I usually submerge it in a tub full of Purple Power de-greaser and let it soak a few days. Whatever is stuck to the part will come off like butter.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 03-11-2010, 11:51 PM   #15
Jeffs70
Jeffs70's Avatar
Re: Degreasing
I tried everything possible to clean mine and the only thing that worked was scraping the thick crap off and then taking a solvent brush and a little gas in a can cleaned the hell out of it better then anything else I found.
Jeffs70 is offline   Reply With Quote
Old 03-12-2010, 12:14 AM   #16
culp7
HickTown
culp7's Avatar
Re: Degreasing
anyone spray that cheapo oven cleaner on the motor and use it like engine degreaser??
1993 Ford Mustang Vert w/ 2.3
1969 Chevy C/10 w/350
1968 Chevy C-20 w/250
1976 Dodge Aspen W/ 225
2000 Toyota Tundra w/4.7
1987 Dodge Ram D-100 w/360
255/70-15
___________
(oo)══╬══(oo)
culp7 is offline   Reply With Quote
Old 03-12-2010, 12:16 AM   #17
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: Degreasing
Sand blast it.
Zoomin is offline   Reply With Quote
Old 03-12-2010, 12:41 AM   #18
bigblockorange
Re: Degreasing
I've had the best luck with a puddy knife, easy off and a hydorspray/carwash. It works better than engine cleaner. Good luck BBO
I guess you could say I’m not really lazy I’m just real good at doing nothing!!!!
bigblockorange is offline   Reply With Quote
Old 03-12-2010, 02:20 AM   #19
UltraBlue71
UltraBlue71's Avatar
Re: Degreasing
Castrol Super Clean is good but kinda spendy, So is Simple Green, Oven Cleaner is good, But I gotta agree with the sandblasting as the best method!
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG...
71 LWB
UltraBlue71 is offline   Reply With Quote
Old 03-13-2010, 01:48 AM   #20
Farmstore34
Re: Degreasing
Oven cleaner is a great idea, thanks! Someone told me sandblasting is not very effective because the media either bounces off or gets stuck in the grease. True?
Old 03-13-2010, 07:11 AM   #21
eagleuh1
eagleuh1's Avatar
Re: Degreasing
Putty knife, old wire brush,new wire brush then paint thinner with heavy duty stiff parts cleaner brush, then citrus based soap cleaner and garden hose. Worked for me.
Good luck.
eagleuh1 is offline   Reply With Quote
Old 03-13-2010, 09:01 PM   #22
chev-obsession
chev-obsession's Avatar
Re: Degreasing
try using a steam cleaning pressure washer.... like a hotsy or hot jenny. they will take just about anything off when it comes to greasy, oily messes.
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 03-13-2010, 10:46 PM   #23
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Degreasing
I used combo of pressure washer putty knife screwdriver sandblaster oven cleaner wire brush wire brush on a electric drill
id say HOT water would be great!
sandblasting ate thru grease as long as it wasnt really thick for me i only had lil spots here and there....
John
1999 Toyota Tacoma 4x4
Old 03-13-2010, 11:01 PM   #24
big_al_71
big_al_71's Avatar
Re: Degreasing
heavy duty degreaser and a pressure cleaner worked for me pretty well...then primered and painted...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
