03-11-2010, 09:22 PM | #1 |
Getting closer..
Hi all, just wanted to share some more pics of my progess. I haven't posted many pics of the project. Here's one of the grille, which is going to get repainted (black again) I made an insert out of some aluminum mesh I had. The hole you see is for the hood pull. Once I put the mesh in and fit the grille back on the truck I had to figure out how I was going to open the hood. So there will be a stainless "eye" bolt mounted through to the pull bracket and will just stick out far enough for you to put you finger in and pull. I am still debating if it will be permanent.
Has anyone else got an idea of how else I could open the hood without having the hole in the insert. Here is also a pic of a tranny support bracket I had to replace(actually had to make it) on the passenger side. That good old Canadian road salt always find a hiding spot and goes to work. old one, and new one mounted. |
03-11-2010, 09:36 PM | #2 |
PROJECT 7DEUCE
Re: Getting closer..
Can we get some better pics of that grill it looks killer..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
03-11-2010, 09:44 PM | #3 |
Hopefully the next pic of the grille will be when I finally get it mounted, shouldn't be to much longer, I do plan to show it off don't worry, thanks,
03-11-2010, 09:45 PM | #4 |
The Older Generation
[QUOTE]Has anyone else got an idea of how else I could open the hood without having the hole in the insert.[/QUOTE
You might be able to do this... http://67-72chevytrucks.com/vboard/s...ad.php?t=61406 LockDoc
03-11-2010, 10:01 PM | #5 | |
[quote=LockDoc;3855008]
03-11-2010, 10:38 PM | #6 |
a cable?
