Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-13-2010, 10:26 AM   #1
ont_guy_38
ont_guy_38's Avatar
Ring gears spacers
Purchased a rear end sight unseen because the price was so good but when i got it home and opened it up it,s a posi with 3.90 gears and a ring spacer.I want to change to 4.11 or even 4.56 because of my tire size but I have read that running a spacer is not the smartest thing to do.The truck will be mostly street driven (car cruises and such) and the odd trip to the track.Oh ya the tires are DRs also.Anybody out there runnig spacers on their gears?
ont_guy_38 is offline   Reply With Quote
Old 03-13-2010, 06:02 PM   #2
djracer
djracer's Avatar
Re: Ring gears spacers
Is it a twelve bolt truck rear?
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 03-13-2010, 07:12 PM   #3
ont_guy_38
ont_guy_38's Avatar
sorry forgot about that , no it,s a 10 bolt Dj ,no thick gear available
Old 03-13-2010, 07:17 PM   #4
hotrod 80
mini truck racer
hotrod 80's Avatar
I've run them before and had no problems . Some of the cheaper ones have runout problems , seen them as bad as .003 . if the correct longer hardware was installed , the inside diameter where it meets the carrier is correct and the runout is good it will probably be ok . I wouldn't run on if i had the choice , but if the price was right ?
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
