smooth roll pan and tag
i want a roll pan for my 84 truck. i want to get the grant kustoms 3 piece but at 180 is more than i want to spend. i have found the smooth pan with no tag cutout for only 80, where would i put my tag?
thanks matt |
Re: smooth roll pan and tag
My bad...Misread.
With enough time and money, you can do anything Quoted from my father 1976 C-10 Project Last edited by SevenSeries; 03-15-2010 at 06:14 PM. |
The One And Only !!!
Matt,
Take a look here; http://www.mar-k.com/catalog/catalog.asp they are a site vendor and members get a discount so I hear.....
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
some people mold it into the tail gate
85 C-10 ShortBoxChevy! Build Thread of my 85' C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=367919 |
Right in front of you.
Uh....make one? Some 18-20 Gauge metal from the hardware store, cut oversize the "depth" ya want the plate to "sink", then bend the sides using C-clamps clamped to a bench....unless ya have a freind with a sheetmetal brake....cut out yer pan for the new insert ya just made and weld the sucker in.....
Pinstriping by Josh '78 Chevy Silverado SWB (lowered, 454) '90 Chevy Sport Truck '68 Dodge Charger R/T 1930 Ford Model A |
I have mine in the window until I decide what to do with mine. Planning on the kit that slides it into to top of the bed rail, but it's not cheap so I may find the components and build my own.
#7 | |
On that note check THIS out, Could be mounted under a roll pan with a little fab work.... ![]()
I have car A.D.D.
The flip license plates are a great little item. They are on a lot of hot rods. But I have seen a couple things go wrong while using them. People air out on top of them without folding them first, either smashing or dragging them off. Or people getting pulled over for forgetting to expose them again before going down the road. Just something to keep in mind.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
That would be my luck, I would forget to raise it and crush the tag. I've seen those and like them but I think I would have bad luck with that one. The one I want is $250 but I think I could make one for uder $100 easy and just have it go between the bed and cab or try to tuck it in the rail.
Fun Stuff
![]() Join Date: Jan 2010
Just get the motorized flip one and have it activate when you turn on the key.
Jay 68 C10(project) 88 Honda Accord(DD) 93 Chevy Astro EXT 2wd |
Well, My truck isn't bagged so I don't have to worry about rippin it off. But I will spend that $140 plus on something else since I have everything sitting out the the shop to throw one together in little over a hour.....
It'd be alot cooler if you did
I've got the stuff to do an auto-flip down on my truck, but really don't have anyplace to put it where it won't look goofy when flipped down. I'm liking the Mustang idea that slide up.
I also have a Lexan window with the plate box in molded into it, but I'm not too big on that either. |
good ideas, keep them coming
thanks matt |
