small block distributor problems
I have a 1970 k20 that i just put new heads on, and when i went to adjust the distributor i found that it is pinched tight against the fire wall, and to move it i have to jack up the transmission so the front of the engine lowers and pulls the distributor away from the fire wall. Has any one seen this, and is there a smaller HEI coil i can put on it, what are my options?
yes, i do
Re: small block distributor problems
its probably cause the motor frame mounts are on the rear holes and clearance back there gets real tight. is this an upgrade from a points dizzy? have you tried taking the cap off then dropping it in? if you still can't get it to go in then you can buy a points eliminator kit that replaces the points turning the dizzy into a more digital dizzy.
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
60-66 Nut
I've heard that the '67-'72 K series trucks don't really have enough clearence for an HEI. Was this distributor in this truck prior to the head change?
i KNOW EXACTLY WHAT YOUR TALKIN BOUT, i have a 69 blazer with hei, i bought it that way well,,,,,,,,, they beat the firewall back with a hammer.
Tags |
coil conversion, distributor, fire wall, transmission |
