Old 03-16-2010, 04:58 PM   #1
72stepside4WD
Why are my Rocker Arms Breaking?
About 2 weeks ago I had a backfire (through the carb) problem that was the result of a broken rocker arm. My mechanic replaced the rocker arm and told me that he rarely sees this and thought that the rocker must have been defective. The truck ran great home from the shop and then sat for a week. 20 minutes into my next drive the same backfire noise started happening again. This time it turns out to be another broken rocker arm on a different cylinder. Both broken rocker arms happened on the same side of the engine. What could be causing this? THANKS FOR YOUR HELP!
72stepside4WD is offline   Reply With Quote
Old 03-16-2010, 05:06 PM   #2
dan76
Re: Why are my Rocker Arms Breaking?
Is this a recently rebuilt engine?
dan76 is offline   Reply With Quote
Old 03-16-2010, 05:11 PM   #3
72stepside4WD
It was rebuilt about 4 years ago and has less the 4k miles on the rebuild. Also, it was rebuilt before I owned it. Thx.
Old 03-16-2010, 05:16 PM   #4
Ticker
Do you have a picture of the broken arms? Seeing the failure mode will help a bunch in determining where the issues are.
Are there any marks on the stud?
Unless it's just a mechanical failure from the rocker ball galling, these almost always occur due to bad valvetrain geometry in some way.
No other changes to the engine...?
Ticker is offline   Reply With Quote
Old 03-16-2010, 05:47 PM   #5
72stepside4WD
I did keep the original broken arm, and will upload a picture. There are no other changes to the engine.
Old 03-17-2010, 12:22 AM   #6
72stepside4WD
Attached are the pictures of the Rocker Arm. It was a hairline split. I do not have the stud.
Old 03-16-2010, 06:21 PM   #7
dwaite72lnghrn
I would check the timing. If it were an older engine I would say the timing chain jumped on you.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 03-16-2010, 07:02 PM   #8
LONGHAIR
With 4k miles since a rebuild, I would doubt that, especially since he said it "ran great" on the way home from the repair. A jumped timing chain would result in seriously retarded valve timing and ignition timing, it would run really bad....if at all.
Like ticker said, Are there marks on the studs? It is possible that the cam lift is more than the rockers can handle, but that usually bends pushrods...
How about the rocker balls? Galling?
Certainly the ball was replaced on the broken rocker arm?
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 03-16-2010, 07:40 PM   #9
cdowns
cdowns's Avatar
are the heads vortecs? stock they're very limited in lift and r usually machined and speings changged for higher lifts
Old 03-16-2010, 11:05 PM   #10
PDW HOTRODS
PDW HOTRODS's Avatar
They might be a cheep brand. I had the same problem, I had 2 brake. After the second one, I bought a whole new set and have not broken any more. It may have taken a few miles, and a few heat cycles for them to start braking. I would still check everything else also.
PDW HOTRODS is offline   Reply With Quote
Old 03-17-2010, 12:30 AM   #11
63chevyll
gets board easy.......
63chevyll's Avatar
I had some speedway rocker arms do the same thing........but only at high RPM, but have never had a stock one break like that,
Were the rockers replaced at rebuild?
What oil are you running?
possibly the fulcrum balls got mixed up during rebuld??? even though i have ran many that way, maybe some of your had wear
63chevyll is offline   Reply With Quote
Old 03-17-2010, 01:32 AM   #12
Ticker
I should have said this, but the area where the rocker ball goes is the most interesting
But, if f there are no marks on the stud...then I call junk rockers. I have *never* seen a fracture like that Do you know what brand they are?
You definitely need to check the valvetrain geometery before doing anything, though. I don't like the device below much...but it will tell you if things are way off, which they'd have to be to break a good rocker.
http://www.summitracing.com/parts/PRO-66789/
These are the rocker arms I'd replace 'em with.
http://www.summitracing.com/parts/CCA-1212-16/
You're sure to hear you should go with roller tips, full rollers, 1.6 ratio, etc. Don't. Just replace the stock rockers and get back on the road.
Old 03-17-2010, 01:40 AM   #13
blwnk5
blwnk5's Avatar
Replace all of them i f one broke their all going to brake sooner or later the mech should have done this when the first one broke
STROKEM OR POKEM
blwnk5 is offline   Reply With Quote
Old 03-17-2010, 05:17 PM   #14
72stepside4WD
So the mechanic said that the push-rod was bent and that he sees "stress" in the other rockers. He said maybe whoever rebuilt it did not match the push-rods with the cam (he assuming they did not use a stock cam).
The mechanic said if it were his truck, he would pull out the cam to see what size it is and then replace all the rods and rockers match up. What do you think? He said, "It's not looking good."
Old 03-17-2010, 06:04 PM   #15
Ticker
Um....no. There is no reason in the world to remove the cam, and in fact it's not possible to find the correct pushrod length that way.
If there are no witness marks on the rocker studs, then you just need to measure what length pushrods you need and order them along with a new set of rockers. Everything you need is in my post above, linked below.
http://67-72chevytrucks.com/vboard/s...8&postcount=12
You also need to check very carefully for coil bind; I suspect in the end this is what caused the failure more than the wrong length pushrod. If you look at the valve stem, is the rocker
contacting it in the middle?
Valvetrain checking springs:
http://www.summitracing.com/parts/CCA-4758-2/
Air hold fitting
http://www.summitracing.com/parts/WMR-W84005/
Valve spring compressor, on car
http://www.summitracing.com/parts/PRO-66784/
Old 03-17-2010, 11:38 PM   #16
Captainfab
60-66 Nut
I would suggest also checking spring retainer to seal/guide clearence
Old 03-17-2010, 11:50 PM   #17
Ticker
- basically all clearances need to be checked at this point. Normally I'd say piston/valve as well, but I guess we'll see where the rest of the stuff comes out.
Old 03-18-2010, 01:09 PM   #18
72stepside4WD
If I do everything above, my only concern would be that it ends up being a band-aid for a bigger problem. What are the chances there is a bigger problem, and is my only other option tearing the engine apart? Should I just see if this solves the problem?
I really appreciate everyones input!!
Old 03-18-2010, 05:20 PM   #19
Ticker
Well, there are a couple of pieces here. If the rebuilder screwed up something so simple, then you have to wonder about the rest of the engine But the only fix for this would be to tear the thing down...and that's certainly not free. So for the shortblock you have to decide how confident you are. Nobody can give you that answer you could always at least just pull the heads to have a look....but honestly it wouldn't tell you much.
For the rocker breaking, you're going to check everything...so at least on the valvetrain geometry you'll be sure that it's right and you won't break anything else there.
If it was me, I would probably roll the dice on the shortblock and square away the rockers. Do not use this to kick my a$$ later if the thing goes up
rocker arms
