03-16-2010, 06:02 PM | #1 |
when using a 700r4 trans do i need adapter on speedo cable?
my 71 GMC has a 700r4 trans. the speedometer that was on the truck originally will not screw into the 700r4. the truc originally had a TH400 in it. do i need a new aftermarket cable or some kind of adapter on the cable to fit in the trans? thanks
03-16-2010, 06:24 PM | #2 |
Re: when using a 700r4 trans do i need adapter on speedo cable?
good question. subscribed, I believe you need a turbo 350 cable though buuuut I could be wrong, I havent tried hooking mine up yet
1967custom |
03-16-2010, 07:13 PM | #3 |
sharp as a marble
I have done this swap several times, and the existing speedo cable should screw onto the 700r4 trans. Just got finished doing a 200r4, and it screwed right on.
03-16-2010, 07:17 PM | #4 |
Yup should just screw right in. TH-350 to 700R4 to 4spd manual now and all with the same spedo cable.
03-16-2010, 07:54 PM | #5 |
Moderator
Later 700R4's have the VSS sender, older ones have the speedo gears. The tailshafts can easily be swapped and the TH400 should screw right in. Go to the parts store and get a 4wd speedo cable, they're a bit longer and fit perfect.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
03-16-2010, 11:17 PM | #6 |
hey sorry guys but there was originaly a th350 not th400, as for what year the 700r4 is il try to see if i can get some numbers off of it. do u guys know where the numbers would be on the case? thanks
03-16-2010, 07:54 PM | #7 |
isint a 400 speedo cable different from the turbo 350 though?
1967custom Last edited by michael bustamante; 03-16-2010 at 07:56 PM. |
