Color By Krylon
Does anyone know if someone makes a kit to raise a swaybar?
Why do you want to raise your sway bar, lowered truck? I think it is at that height for a reason. I dont think you are supposed to modify it, but I could be wrong.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
driving is in my blood
Make a kit? No. But it shouldnt be too difficult. Just cut down the "legs" of the tabs in the middle, and fab some raised mounts for the a-arms.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
Fabrication would be easy:
Get a small piece of angled steel from a local yard. Weld it to the frame so you have a level surface (like stock setup) for the frame bracket and bushing to mount on. For the spacers on the A-arms you could buy some rectangular steel tubing (heavy wall) and just use it like a big washer. Drill a couple holes in it and get some longer bolts, then bolt it all up.
world class smart ass!
Drill out the rivits and flip the bushings, inside of the mount, then bolt the brackets back to the frame...
Lifts the bushing up about 2" or so...
Aric 75 2WD BLAZER (never ending project) -some day maybe- 02 2500HD CREW CAB 4X (daily drive) -8" lift 37s and 22s- ____ ![]() |
