Old 03-17-2010, 08:51 PM   #1
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
my truck is eating Power steering belts??
I have had to put 3 belts on in the last year..they all get stretched out and the steering get jumpy because the belt slips....when its jacked up it turns from stop to stop OK....and the pump is on the stock mount
looking for help...pump or sterring box???
if its the pump I'll hold out since the new motor has a pump on it
thanx
JEff
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 03-17-2010, 08:59 PM   #2
hayhauler71
hayhauler71's Avatar
Re: my truck is eating Power steering belts??
Possibly worn pulley or misaligned pulleys.
hayhauler71 is offline   Reply With Quote
Old 03-17-2010, 09:02 PM   #3
72swb_327stroker_?
knuckle buster..
72swb_327stroker_?'s Avatar
X2! Its most likely the pulleys not the pump.
Get out your straight edge and check your alignment from pulley to pulley.
good luck!
_______________________________________________________________________________
Eric
THIS SITE ROCKS!!!
Check out my suburban on 20's with fresh paint!
Click here to support the site
Check out the Member Photo Gallery here
StreetCruizin
FAQ thread
Site vendors list (scroll down to vendors in red)
join the the smilies fight club
72swb_327stroker_? is offline   Reply With Quote
Old 03-17-2010, 09:07 PM   #4
Hottrucks
Hottrucks's Avatar
nope not that easy....stock mounts and pullies
Old 03-17-2010, 09:14 PM   #5
50mercfan
50mercfan's Avatar
sounds like alignment issues, is your belt too wide for the pulleys? try running the engine and watching to see if anything is bent, or if your pump is moving.
50mercfan is offline   Reply With Quote
Old 03-17-2010, 09:16 PM   #6
72BLUZ
72BLUZ's Avatar
what they said
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream.
It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan
72BLUZ is offline   Reply With Quote
Old 03-17-2010, 09:19 PM   #7
jamie72
jamie72's Avatar
using cheap belts???
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 03-17-2010, 09:38 PM   #8
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Here's some good info here.
s/t
http://docs.google.com/viewer?a=v&q=...qm2FhH5B7OCYNg
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 03-17-2010, 09:45 PM   #9
Hottrucks
Hottrucks's Avatar
ok guys these are all great ideas BUT
the pump is tight, things are lined, up not bent, and I have been running a NAPA gold belt, seems to be the right width too..
this is why I kinda stumped...
Old 03-17-2010, 09:53 PM   #10
leddzepp
Moderator
leddzepp's Avatar
You need a new pulley, that's my guess. When replacing use the proper tool to pull and install it, or the new one will wobble too. Watch it while the truck is running. If there is any wobble to it, there is your problem.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
