E.H.F.D Engine #2
Strange 6.0 Problems
Ok so my 03 2500HD has been acting a little weird lately. Every once in a while when i start it up and head down the road it shifts from 1st right into 4th gear. If i get out of the throttle, it will go back to 1st, but then when i get back on it it shifts back to 4th. I have to correct it by stopping to shut er down and fire it back up. Ive also noticed every time it does this, i look over and my electronic 4x4 shows 4Lo, even though it def is still in 2wd.
-NICK '72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation '89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205 '15 Chevy 2500HD CCSB High Country Duramax '22 Tahoe Premier Duramax |
Truck Enthusiast
Re: Strange 6.0 Problems
It does sound like a sensor problem, or electrical
'85 swb |
![]() Join Date: Jan 2003
It is common for the push button 4x4 switch assy to fail and do some weird stuff including light up the service 4wd light. Out of couriousity, how do you know it is going all the way to 4th? Have you tried to put it in 3rd and drive and see if it still happens? This should keep it out of OD/4th.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec -Gibson Stainless Cat Back Swept Side -SS Wheels 2005 Honda CRF250R 2006 Honda CRF150F |
E.H.F.D Engine #2
Yes I forgot to mention, If I manually shift it will go to the gear I pick. But in Drive it shifts straight to 4th and obviously wants to shut off because its only about 15mph. I busted out the grinder today and cleaned up the ground thats on the frame under the drivers door. we'll see if that fixes anything, i heard that one can cause some funky problems and it was a bit corroded.
