Shlong Bed Club
Pipe Notch
stupid question, but does anyone have pics of a 60-66 with rear bags and just a pipe notch? (preferably aired out)
"If it ain't broke, hit it with a hammer, then fix it.." ![]() |
Shlong Bed Club
Re: Pipe Notch
no one?
Re: Pipe Notch
Get at shotbed,he welding some in his.I cant remember right off what size it was
http://67-72chevytrucks.com/vboard/s...=332884&page=9 |
Re: Pipe Notch
'77 GMC SWB '66 SNB (Project) Battle Ground, WA |
Shlong Bed Club
Re: Pipe Notch
exactly what i was was looking for, got any side pics aired out?
Re: Pipe Notch
Re: Pipe Notch
The notch was done by my friend Dan at Sick Industries. Its simple and works great. The cross member in front of the rear end has a small notch in it too to clear the rear end when air'd out. I had to raise the bed floor 2 inches to clear also.
[IMG] ![]()
SAVING ONE TRUCK AT A TIME
![]() Join Date: Feb 2010
Re: Pipe Notch
Nice truck i just got my truck back from dan. He cut the frame down and the bed. He does killer work.
#9 | |
Re: Pipe Notch
Your right dropped spindles and dropped lower control arms. I may take one of the two out and see how it sits. I think it is too much drop. The bags have to get 90% full to lift. Cross member lays out long before bags do.
Shlong Bed Club
Re: Pipe Notch
Looks great. i assume you're running drop spindles in the front too? thats the hieght i was looking for in the rear, thanks for the pics.
Re: Pipe Notch
Heres my pipe notch welded in
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
Re: Pipe Notch
I did a search, but does anyone have a link for a good 'how to" on the pipe notch?
Re: Pipe Notch
I've always just unbolted the rear hangers or coils and let the truck down on the axle to get my mark. Easiest way for me to figure out where to cut. Then just measure how much farther you have to go to reach the lowest point, laid out or wherever and cut ur piece of pipe to give you that much notch. Trace it on the frame, cut it out and weld it. It goes pretty quick that way. Has for me anyway.
#14 | |
Re: Pipe Notch
#15 |
Resistance is Futile
Re: Pipe Notch
lakeroadster; with out going into a complete engineering seminar, how do you make that calculation? Just curious.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#16 | |
Re: Pipe Notch
Also.... What if a pipe notch similar to what is pictured above is boxed on the inside? What effect would that have to restore that strength?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-26-2010 at 09:27 PM. |
#17 |
Re: Pipe Notch
My notch I used .25 wall tubing and then used 1/4"x2" plate and welded on top of the notch to top of frame. Nothing fancy but it works.
#18 |
SSN 706
Re: Pipe Notch
Thanks for the time to figure this out John. I knew you just were'nt talking $hit.
#19 |
Re: Pipe Notch
Ok, thanks John.........that's cool!! Now my question is what is the difference from boxing to '' heavy structural steel members that are added to the existing frame rail.''?
Isnt that just the same as boxing on the outside of the frame? And, do the bolt holes reduce the section modulus of the frame?
#20 |
Re: Pipe Notch
We may have to start paying consultation fees soon!!!
#21 | |
Re: Pipe Notch
I guess to make a more extreme example, using the 4.75'' frame rail from page 1 (d).....what if, centered on the frame rail, one was to holesaw a 3'' hole thru the frame. What does this do? My father was an engineer at Caterpillar for 40+ years so I'm used to physics, equations, and math blowing holes in my 'common sense'. ![]()
#22 | |
Re: Pipe Notch
John, did you run the numbers on an "off the shelf notch"? (I wanted to attach a pic of the one I have from Early Classic Enterprises, but can't find it on their site now) I'm very curious to see how this stacks up the to other designs shown here. I have not installed it because I decided that it probably wasn't necessary on my '63. I was thinking about using it on my '68, but I'm not sure if thats a good idea or not now.
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
#23 | ||
Re: Pipe Notch
I did consider the strength impact when reducing the height of my frame channel. I figured the use of the heavier walled material (.250" steel plate c-notch) w/boxing it in (using .1875" steel plate) would restore the majority of the strength. Seeing those numbers crunched, I'm going to re-evaluate/scrutinize my set-up & consider the possibility of plating the outer wall of my frame for additional assurance.
#24 |
Shlong Bed Club
Re: Pipe Notch
Keep the pics commin' guys! i've decided that a pipe notch is all i need for what i want. i got the pipe Wednesday and will probably start in on it this tuesday night. i'll try to take some pics to show progress. from the pics it looks as though i'll get plenty of drop with a pipe notch. thanks again guys.
#25 |
Jonny
Re: Pipe Notch
Without detailed engineering experiments and only sense to work with. I would say that by notching half the height of the frame, using the same grade/thickness steel, and boxing the back side, to include going a distance equal to the height of the frame forward and aft of the notch, ther would be little to no degredation of the integrity of the frame. And lets face it, if you're notching your frame, you're not planning on heavy duty work.
Oh, and the gas tank behind the axle? Really? Even a topped off 40 gal tank only weights about 300lb!
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
