Old 03-24-2010, 05:42 PM   #1
BIG KRIS
BIG KRIS's Avatar
drop spindels & big brakes
Which drop spindals will allow you to upgrade to aftermarket big brakes,so you don't have to switch them out at a later date?
Flowershop Hip Hop & Street Rods
Dropmember
83 Custom Deluxe Almond on Almond
85 Silverado White on Red/Now Chevy LeMans Blue
Rendering in Truckin magazine vol 36 no. 11,2010
BIG KRIS is offline   Reply With Quote
Old 03-24-2010, 07:40 PM   #2
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: drop spindels & big brakes
The CPP Modular 2.5 drop spindles would be my firsst choice.
http://www.classicperform.com/NewPro...op_Spindle.htm
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 03-25-2010, 12:42 PM   #3
bagged69chevy
the modular spindle is a 2.0" drop not a 2.5" FYI
I got a set of them recently.. they are REALLY nice!
bagged69chevy is offline   Reply With Quote
Old 03-29-2010, 12:11 PM   #4
Ovidiu
I am about to start working on my truck as well and researching some brake options...
The CPP modular drop spindles are nice and I want to get them, is there a way to bolt up c6 z06 calipers to them?
You can see my vehicles in my FQuick Garage.
Ovidiu is offline   Reply With Quote
Old 03-29-2010, 08:42 PM   #5
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
The spindles tuck the wheel in 1 1/8" inwards per side... this matches the rear track width... yuck.... i almost bought a pair untill i read that
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 03-30-2010, 08:09 PM   #6
DKN
Active Member
They are 3/4" narrow per side. The other spindles will push the tire out into the fender. The CPP spindle will allow you to lower the truck more and you can drive with out rubing compared to the old wide spindle. We do have both types. In fact most of the people who buy the new narrow spindle already have the old wide spindle and are fed up with the tires rubbing the fenders are willing to buy replacement spindles, do the install, and get another wheel alignment.
I'm sharing because with the old spindles more often than not we hear complaints about the tire rubbing and they want to lower the truck more.
Danny Nix
CPP
DKN is offline   Reply With Quote
Old 03-30-2010, 08:33 PM   #7
smashingchuck
wow... why not buy wheels with the correct back spacing?
78 Build Thread
4Runner Build
Old 03-30-2010, 10:41 PM   #8
DKN
Active Member
You can, and when youre done you will have the exact same thing as the new spindle, and an old set of front wheels. As long as youre going to buy new spindles, just buy the spindles that work and avoid buying another set of wheels.
Danny Nix
CPP
Old 03-30-2010, 11:49 PM   #9
87chevy.com
i guess when i called, they only offered the ones that were tucked in 1 1/8 " more than factory... i was hell bent on one style of wheel that i didnt even buy at the time, but in the end i bought a wheel that i loved and had the same offset. its so close enough to the fender it cut the tire once comming out of a steep drive way. rolled the fenders and havent heard a peep from the front. me personally, i strongly dislike the tucked in wheel look.
clint
Old 03-31-2010, 03:20 AM   #10
oldspowered67C10
Im gonna get the CPP spindles, allows you to run a deeper wheel(less backspacing) which looks better to me. I also like the idea of 13" rotors but Im not too excited about the OEM style caliper they use in their kit.
Danny, Ive got a CPP catalog(#15) and it says that the 14" kit was gonna be available late 09, any news on that? Also, would you guys sell the parts for the kit seperately(e.g. just the spindles, hubs and rotors w/o the calipers or hoses)?
oldspowered67C10 is offline   Reply With Quote
Old 03-31-2010, 06:14 AM   #11
BIG KRIS
BIG KRIS's Avatar
Ok maybe i should have asked wich spindel will allow you to convert to wilwood or baer brakes and calipers at a later date?
Dropmember
Old 04-01-2010, 09:42 AM   #12
andrewmp6
Have you looked at http://www.abspowerbrake.com/
Old 04-01-2010, 10:05 AM   #13
BIG KRIS
BIG KRIS's Avatar
No but I will
Dropmember
Old 04-01-2010, 12:09 PM   #14
Ackattack
Ackattack's Avatar
When I put my stock diameter rotor on my CPP modular drop spindle, the back of the rotor was hitting the spindle. Some light grinding took care of it.
Ackattack is offline   Reply With Quote
