Old 03-25-2010, 10:52 PM   #1
vegaschevy
Replacing body mounts
I was installing new body mounts today and have a couple big washers that I was wondering if they go between the bushing and body on the rear. It was a counterparts replaceable body mouunt kit. Maybe someone else as used one. On the rear I have a nut, washer, cone bushing, then frame then upper bushing then body. I have the bolt with sleeve going through it. I was thinking the other washer I have goes between the body mount and body.
anyone know?
The fronts seem to be together correct. There was a square piece of metal between the bushing and the body that I left in there for the new mounts.
vegaschevy is offline   Reply With Quote
Old 03-25-2010, 11:03 PM   #2
highperf4x4
Re: Replacing body mounts
I need to know too.
highperf4x4 is offline   Reply With Quote
Old 03-25-2010, 11:07 PM   #3
chas350
Does this help?
http://www.lmctruck.com/icatalog/cb/full.aspx?page=32
"I'll Procrastinate Tomorrow"
quote by LEEVON
71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's
70 K20 long fleet
98 G3500 work van
chas350 is offline   Reply With Quote
Old 03-25-2010, 11:16 PM   #4
vegaschevy
It helps a bit, but I am wondering with the aftermarket ones I bought if they are going to be installed the same way roughly....
Old 03-25-2010, 11:21 PM   #5
chas350
This one maybe?
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=33
quote by LEEVON
70 K20 long fleet
98 G3500 work van
Old 03-26-2010, 10:07 PM   #6
chevy_mike
Never Ending Projects
chevy_mike's Avatar
When I tore apart my '68, both the front and rear cab bushings had washer top and bottom, so to answer your question, yes mine had a washer between the cab and the top bushing.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 01-11-2012, 03:00 AM   #7
lianalet
Thanks for the diagrams to properly replace the bushings. My problem is getting the nuts off the body bolts. I finally got the nut off the front mount after taking out the radiator. How do I gain access to the top of the bolt on the driver side middle mount since it simply spins with the nut? Got any tips to make this task any easier?
lianalet is offline   Reply With Quote
