03-26-2010, 02:14 PM | #1 |
when checking your fuel level with a DOWEL ROD...
In a behind the seat tank.....how many inches is equal to a gallon? I'm looking for a fuel sending unit at the moment and am trying to figure out my fuel level. I'm sure some of you guys have been there.
03-26-2010, 02:32 PM | #2 |
Re: when checking your fuel level with a DOWEL ROD...
I've been there but I use to check it by lighting a match and looking inside.
Seriously, I would fill it up and record the miles driven and gallons used then compare that to the tank capacity. The shape of the tank might be such that you can't make a linear scale. |
03-26-2010, 02:38 PM | #3 | |
Match...Gas...LOL...I think I will stick with the dowel rod. |
03-26-2010, 07:56 PM | #4 |
The tank being the shape that it is will cause a variation in the gallons per inch as measured on a stick. When the tank is below one half, each inch will be close to 1.1 gallons. If the gas is closer to the top each inch will be less than a gallon.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
03-28-2010, 12:36 PM | #5 | |
That can't be right-everybody knows that the last half of the tank goes faster than the first half!
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
03-28-2010, 05:39 PM | #6 |
You could always run it out of gas and tap a brass plug in the bottm and top of the tank behind the drivers seat and run some clear fuel tubing between them. Then you will always know how much fuel is left.
1970 GMC truck 1988 Harley 1200 Sportster Last edited by kevmic28; 03-28-2010 at 05:42 PM. |
