Old 03-26-2010, 04:24 PM   #1
oldschool18
oldschool18's Avatar
colorado brakes
has anybody ever had a problem with the rear brakes locking up on there mid00's colorados and a fix if they know of one
oldschool18 is offline   Reply With Quote
Old 03-27-2010, 07:57 AM   #2
truckdude239
truckdude239's Avatar
Re: colorado brakes
i know they dont last long but never hear of a problem with them locking up
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 03-28-2010, 09:36 AM   #3
oldschool18
Re: colorado brakes
yeah its weird there are 3 trucks that are doing it and cant figure out why thet are locking up
Old 03-28-2010, 10:06 AM   #4
bwood
bwood's Avatar
Re: colorado brakes
Is it just locking up once in a while at low speeds? The 04 Colorado we had at work would be extra touchy for just a minute when you first took off in the morning. I would pull up to the first sign in the parking lot and it would lock down, after that it was fine. My 99 S10 did the same thing.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 03-28-2010, 02:13 PM   #5
clinebarger
Re: colorado brakes
Heres the TSB for this.
Excessive Brake Grab, Aggressive Drag, Lock Rear Brakes Drums and Shoes (Remove High Spots from Drum Surface Finish)
Models:
2005-2008 Chevrolet Colorado
2005-2008 GMC Canyon
Condition
After the vehicle has set for a while, during the first few stops, it will feel like the brakes are grabbing excessively. In addition, the tires may chirp and/or leave skid marks during braking.
Cause
This condition may be caused by a mirror-like finish between the drum and the brake shoe.
Correction
Remove the rear drums and inspect the rear axle seals and wheel cylinders for leaks. Inspect the brake shoes for contamination. If no leaks are found, perform the following:
Important: Only replace the rear brake shoes if a leak is found and the shoes have been contaminated with fluid from the rear axle or wheel cylinder.
1. Machine both rear drums to eliminate high spots.
2. For the left side, replace the drum brake star wheel adjuster with P/N 19133371. This adjuster is a 15-tooth adjuster.
Right side..
Important: P/N 19133371 is threaded for the left side only. DO NOT attempt to install the adjuster (P/N 19133371) on the right side of the vehicle.
3. For the right side, grind off every other tooth of the star wheel adjuster. Use suitable dremel and cut-off wheel (preferably a 1-1/4 in X 1/16 ).
4. Reinstall the adjuster and adjust the brake shoes accordingly.
clinebarger is offline   Reply With Quote
Old 03-28-2010, 02:38 PM   #6
truckdude239
Re: colorado brakes
wow i love the install new adjuster oin left side but cut every other tooth on the right side
David fuller
2000 Tahoe 5.3l 378
Old 03-28-2010, 08:25 PM   #7
oldschool18
Re: colorado brakes
Clinebarger I think I am going to have to try that, cause we have ajusted the brakes 2 or 3 times and 2 weeks later they start grabbing again...........thanks everybody for your help
