03-26-2010, 05:11 PM | #1 |
Stock 1/2 ton front coils
Anyone have any stock front coils they took out of a 71 or 72 1/2 ton, small block truck they could measure for me. Pics would be a big help as well. I'm trying to figure out if these are the original stock springs out of my truck. Speculation is they may be 3/4 ton or 73 & ^.
Side by side with ECE 2" drop springs
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 03-26-2010 at 06:12 PM. |
03-26-2010, 05:33 PM | #2 |
Slow Old Timer
Re: Stock 1/2 ton front coils
If I remember right, I was told that stock springs measured 13 inches. Those also look a little beefier so maybe your theory is correct.
03-26-2010, 05:35 PM | #3 |
My Stock springs measure 14" top to bottom (after removing them from the truck). I have a 72 1/2 Ton, 350/350
Oh, and the stock Delco springs I bought to replace them, measured 13.75" top to bottom.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 Last edited by dfwright; 03-26-2010 at 05:39 PM. Reason: added info |
03-26-2010, 07:44 PM | #4 |
That sounds reasonable close to mine. I could see them being 1/2" different after 40 yrs of settling. Anyone else?
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 03-26-2010 at 07:44 PM. |
03-26-2010, 08:45 PM | #5 |
I just pulled a 72 front end apart today, the ones out of it measure a little shy of 13 3/4
03-26-2010, 09:11 PM | #6 | |
I guess the next step is to measure the diameter of the wire used to make the springs. Anyone got a set of calipers they can check that with? Keep them coming. I need as much info as I can get. Here is the issue we (ECE and I) are tying to resolve. http://67-72chevytrucks.com/vboard/s...d.php?t=390476
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 03-27-2010 at 06:39 PM. |
03-27-2010, 06:39 PM | #7 |
No one with stock springs and a dial caliper??? Mine measured .776
03-27-2010, 09:42 PM | #8 |
Old School
My stock 1969 1/2 ton small block front springs measure .778.
#1 Project...69 Chevy swb Fleetside (Dad's truck) #2...1983 El Camino SS (Choo Choo Custom) #3...1974 Datsun truck (4.3L V6/4L60E) #4...1951 Cadillac Limo (1975 Caddy running gear) #5...1938 Dodge M38 3/4 ton Military truck #6...1968 Sportster XLCH trail bike 5 GMC & Chevy parts trucks 68 to 72 Last but not least; My 1978 Harley Davidson Electraglide (trusted & reliable companion for the last 30 years) |
03-28-2010, 10:15 AM | #9 |
Thanks BOZO. That is pretty close to mine. It seems my springs are no different than any other 1/2 small block springs as far as the dimensions. I guess they could still have a different rate if the material is a different hardness.
Anyone else got a set of stock 1/2 ton springs laying around? More information is always helpful. Matt
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 03-28-2010 at 10:23 AM. |
03-28-2010, 10:49 AM | #10 | |
Who needs sleep...
Trip |
03-29-2010, 04:57 PM | #11 |
My springs are 12 7/8 " high. I don't have a set of calipers. The spring diameter is 5 1/2 ".
1970 C10 CST Frank |
03-29-2010, 05:15 PM | #12 |
03-29-2010, 06:23 PM | #13 |
If you go to NAPA's web site the give the hight and coil thicknes of there springs.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
03-29-2010, 11:11 PM | #14 |
Thanks Frank.
1-PU I am only concerned with factory original springs. I'm trying to figure out another issue. |
