03-26-2010, 07:59 PM | #1 |
Question about flip kits...
I'm planning on dropping the rear of my 1986 Chevy c10 another 4 inches with a flip kit. I was just curious if you actually needed to cut the frame and add a C notch or if its not needed. I've heard both that you shouldn't need to and also that you would need to. If anyone could help clear this up for me I would very much so appreciate it. Thank you.
-Allen
...............................____ .................________-|___\____ ..;.;;.:;:;.,;.|__(O)___|____/_(O)| 1986 Chevy Custom Deluxe Nothing like a square body http://67-72chevytrucks.com/gallery/...0&ppuser=45891 |
03-26-2010, 08:10 PM | #2 |
6.0 powered square
Re: Question about flip kits...
what other method of rear drop do you have
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
03-26-2010, 08:12 PM | #3 |
Right now i have hangers and shackles.
03-26-2010, 08:18 PM | #4 |
6.0 powered square
I flip would give 5" drop at minimum, and would require a small step notch drop shocks, shock extenders and pinon angle would be bad you"ll want drop leafs or removed leafs, or get stock hangers and do a flip kit
03-26-2010, 08:21 PM | #5 |
Well what i was wanting would be just another 4" drop on top of the 4 i already have. So i would need to use a C notch unless i swapped back to the stock hangers?
03-26-2010, 11:36 PM | #6 |
you could probly wing it.
if you do the flip-kit, and remove the shackles, leave the hangers and cut the bump stop bracket and mount the bump-stop directily to the frame. but either way, you suspension travel will still be short. Last edited by datguysaL; 03-26-2010 at 11:36 PM. |
03-27-2010, 01:17 AM | #7 |
haha, ford guys...
stock suspension flipped is ok, get some air shocks if u can afford it to keep em from smackn... if u cant afford the shocks, just go slow over buumps..
now sense u have the shackels... i dont know... most likely not man. do you still have the factory ones? if so, have em handy.. if it looks too tight, replace them /w/ stock shackels... btw... lmc says a flip will give you 6in of drop... they are damn close. |
03-27-2010, 01:38 AM | #8 |
you will need a c-notch. flip and 2in shackles works great, how you plan on doin the front?
03-27-2010, 02:17 AM | #9 |
I was trying not to use a C notch just because I dont want to weaken the frame but i guess i wont have much of a choice.
Fiddy9apache- in the front I already have 3 inch drop coils and im gonna use some spindles to lower it another 3 inches
03-27-2010, 09:51 AM | #10 | |
and a c-notch, if dont correctly, will not weaking a frame. Last edited by fiddy9apache; 03-27-2010 at 09:53 AM. |
03-28-2010, 03:51 AM | #11 |
Oh ok thank you. Do you happen to know any places that have the kits to lower the lower control arm?
03-28-2010, 03:56 AM | #12 |
Also with the c notch would i still be able to tow something?
03-28-2010, 10:33 AM | #13 |
6.0 powered square
you'll still be able to tow with c-notch but if you wan't max factory carry loads you'll want to weld it in to be safe and also helper bags
and the lower control arms http://www.summitracing.com/search/M...&Ns=Price|Desc
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 03-28-2010 at 10:33 AM. |
03-28-2010, 03:02 PM | #14 |
Would it be a better to buy the upper and lower together? or would it not make too much of a difference?
03-28-2010, 04:19 PM | #15 |
Do you have to cut out the bed when adding a little c-notch? Thanks... Now I'll go and introduce myself
03-28-2010, 08:35 PM | #16 |
6.0 powered square
03-29-2010, 01:35 AM | #17 |
Wow that's not much of a notch. It gives you maybe an extra 2 inches? Did you end up cutting off the old mounting bracket for the leafs? In your picture it's still on, so I was just wondering if maybe that was cut off if you would still need the notch. Either way I'm going with a notch. Can you post a link to where you bought your flip kit. Thanks
03-28-2010, 08:42 PM | #18 |
03-28-2010, 05:39 PM | #19 |
^^^No you won't have to cut the bed to put in a small c-notch. It helps to pull the bed off to put it in, but you don't have too.
03-28-2010, 11:51 PM | #20 |
oh ok well thank you everyone for your help
03-29-2010, 10:33 AM | #21 |
The leaf spring perch ("mounting bracket") is actually outboard of the frame and doesn't post any issues.
03-29-2010, 07:28 PM | #22 |
6.0 powered square
03-30-2010, 12:03 AM | #23 |
^^^That one is high as Giraffe Pue Nanny!!! Look at this one
http://cgi.ebay.com/ebaymotors/mcgau...item4396817ff9 but I bet if you checked with some of our vendors, they would have a much better price. Check w/ Porterbuilt , he seems to be a He!! of a guy |
