Old 03-29-2010, 09:10 PM   #1
altereddezignz
lay pinch or rocker on PB dropmember
Hey guys i am gonna order a pb dropmember from Nate tomorow. I was curious what all you guys are running to lay pinch or rocker. i wouls liek to run 22 front and rear about a 28-29 tall tire, maybe a 20 front and 24 rear. Looks like ill be using tubular upp and lower control arms.
Thanks for the help
altereddezignz is offline   Reply With Quote
Old 03-29-2010, 09:21 PM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: lay pinch or rocker on PB dropmember
the frame hangs lower than the body so you'll be a couple inches away from laying pinch
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 03-29-2010, 09:22 PM   #3
altereddezignz
oh i have already planned on cutting that all off and boxing it in under the cab.
Old 03-30-2010, 09:53 PM   #4
crawdadfox
crawdadfox's Avatar
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
With Dropmembers and 3" spindles on the old truck and the frame planted on the ground there was 1 1/4" to the pinch weld. With the truck on our drive on rack aired out i had an extra 1 1/4" of drop below "ground zero"...so if you did cut the same amount off the bottom of the frame (i wouldn't) you would lay pinch. I was on a 29.1" front and 29.9 rear tire, if you ran a shorter tire you would be lower....but do you need to be?
Down......with the sickness!!
crawdadfox is offline   Reply With Quote
Old 03-30-2010, 10:02 PM   #5
altereddezignz
Weill I have decieded to use 4x2 and build new rails from just n front of the cab to the rearend. This way I'm nit cutting and reducing the integrity and strength of the frame.
crossmember, dropmember, porter, rocker, slammed
