Old 03-29-2010, 11:04 PM   #1
qu1cks1lver56
qu1cks1lver56's Avatar
Adding overdrive to a TH350?
I know I've seen bolt on overdrive units, but can't seem to find any on the net. Anyone have any ideas on how to add overdrive to a TH350 and not break the bank?
qu1cks1lver56 is offline   Reply With Quote
Old 03-29-2010, 11:07 PM   #2
71STPSDE
71STPSDE's Avatar
Re: Adding overdrive to a TH350?
The most popular is Gear Vendors. They aren't cheap. Around $2400. It would be cheapier to get a 700R4. Just a thought!
71 Chevy Stepside
377/350
71STPSDE is offline   Reply With Quote
Old 03-29-2010, 11:10 PM   #3
Pyrotechnic
Pyrotechnic's Avatar
Gear Vendors and US Gear are the two I know of.
A complete install of a GV (do it yourself) is about $3000 when all said and done, maybe more. The US gear unit is a little cheaper. Not sure what your budget is, but to me it's a waste of money. If you have a stock to mild engine, you're much better off getting a 700R4.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 03-29-2010, 11:21 PM   #4
qu1cks1lver56
Gear vendors, that's the one I remember seeing. $3000, ouch. I think an 700R4 would be much better, anyone know the average cost of setting one up in an old truck like ours?
Old 03-30-2010, 12:14 AM   #5
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
....or try getting a 200-4r (built up of course). The 200-4r is the same length as a turbo350, has a different ratio for 1st gear(and 2nd?) for a better 1-2 shift w/o the bog, and has a slightly lower (.67) overdrive. I think (not sure) that even the spline count is the same...meaning you can use your old driveshaft. I think the only real change other then the TV cable, is the tail mounting location, meaning slight changes to your tranny crossmember. I'm no expert so I could be off on some of these details.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 03-30-2010, 08:31 AM   #6
Conundrum
Conundrum's Avatar
The trans mount is in the same place as a th400, so you would only have to move your trans crossmember back a little ways. I found this info....although i'm not to positive on the accuracy of it, I think the 2004Rs 1st gear is a 2.74. Although it came from TCIs site.
TH350_________TH400
Lo 2.52 2.75____2.48 2.75
2 1.52 1.52____1.48 1.57
3 1.00 1.00____1.00 1.00
200-4R__700R4/4L60E__4L80E/4L85E
Lo 2.78______3.06_________2.48
2 1.57______1.63_________1.48
3 1.00______1.00_________1.00
4 0.67______0.70_________0.75
http://www.tciauto.com/Products/Tech...ear_ratios.asp
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r
http://67-72chevytrucks.com/vboard/s...d.php?t=460030
97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver
220,000 miles, all stock for now
Conundrum is offline   Reply With Quote
Old 03-30-2010, 07:40 PM   #7
coater
I have a TH350 in my '85 and having a motor machined as we speak,but was wanting overdrive also. Are there any computer hook ups for the 700r4? Can you just bolt it up to a mild motor and ride?
coater is offline   Reply With Quote
Old 03-30-2010, 12:51 AM   #8
qu1cks1lver56
thanks for the info.
Old 03-30-2010, 09:26 PM   #9
68GMCCustom
700-r4 and 200-4r only require a a TV (throttle value?) cable...but it has to be setup right or you can burn up the new tranny.
Kurt -
Old 03-30-2010, 11:22 PM   #10
coater
what about just going with a 400 with a lock up converter?
Old 03-31-2010, 08:08 AM   #11
Conundrum
Conundrum's Avatar
You also need to control the lock up converter some how.
Old 03-30-2010, 11:45 PM   #12
qu1cks1lver56
I've got a TH350C with a lockup converter, and I guess my highway RPM's aren't too bad compared to others, I just do alot of highway travel to and from school everyday and would like something lower than 2500 RPM's @ 70mph
Old 03-31-2010, 09:26 PM   #13
3r!c84
Badass
3r!c84's Avatar
all maters about gear ratio ,my th350 screams down the highway at 75mph @3000rpm thanks to the 3.42 gears
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 03-31-2010, 10:51 AM   #14
68GMCCustom
forgot about that. Is there a diagram somewhere for the 4 wire connector and how to rig up a switch for it? I'd like to be able to keep the lockout "locked out" unless I'm cruising 80 or something and need it.
Kurt -
Old 03-31-2010, 03:32 PM   #15
Conundrum
Conundrum's Avatar
Not sure about that, but I do know that B&M has a kit that will control your converter and it is adjustable from 30-90 mph and it doesn't appear that you have to remove the pan to install it. I remember reading a few years ago that you can change a few things in the 2004R and use a th400 kick down wire to control it, but I don't know of anyone that has done it.
Old 03-31-2010, 08:38 PM   #16
68GMCCustom
My tranny builder provided a nice TV cable for me so I'm set there. I'll have to look into the B&M lockout options.
Kurt -
Old 03-31-2010, 09:28 PM   #17
joe231
joe231's Avatar
depends on which length TH350 you have.....the 200-4R is very short.
there are 3 tail shaft lengths available on a TH350. 6", 9", and 12".
the 700 is very close to the same length as a mid length tail shaft equipped TH350. the 200 is very close to the same length as the short tail shaft equipped TH350
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 03-31-2010, 10:33 PM   #18
qu1cks1lver56
haha 3.42's is what I've got. 75 is about 2700rpm for me. which is great for no overdrive, but I'd really like 3.73's and an overdrive.
didn't know this, I thought it was only long or short shaft TH350's.
Old 04-01-2010, 01:23 PM   #19
3r!c84
Badass
3r!c84's Avatar
[QUOTE=qu1cks1lver56;3893899]haha 3.42's is what I've got. 75 is about 2700rpm for me. which is great for no overdrive, but I'd really like 3.73's and an overdrive./QUOTE]
how can i test to see if my lockup converter is working ?
-00 Saturn 5spd
1/4:13:90
Old 04-02-2010, 02:14 AM   #20
qu1cks1lver56
only way i know of, is to unhook the vacuum switch, and run down the highway and see if you have any higher rpm's than normal, then hook it back up and see if its any different.
Old 04-01-2010, 06:41 AM   #21
Conundrum
Conundrum's Avatar
Forgot all about the different tailshaft lengths.
Old 03-31-2010, 09:45 PM   #22
3r!c84
Badass
3r!c84's Avatar
how much will it cost to cut your drive shaft?
-00 Saturn 5spd
1/4:13:90
