04-02-2010, 06:03 PM | #1 |
Overworked and Underlaid
Question about torque convertors?
in a late 70's TH350 what is the stock stall speed.might buy a new convertor but want something with more stall speed than stock since my motor isnt stock.convertor suggestions are welcome as well.engine and trans gurus help me out here.
I'd rather push a Chevy than drive a Ford The Beast-1978 C10 LWB Red-1978 C10 LWB (Uncle Mike)Michael Henry Millett 11/5/1957 to 03/08/2012 Gone but will never be forgotten-RIP (Uncle Chuck)Charles Manning Gulbronsen Sr 1956-2012 Taken from us to soon but you will live on in our hearts-RIP |
04-02-2010, 07:17 PM | #2 |
Re: Question about torque convertors?
We need to more about your engine mods, cam? heads? intake? carb? Stock stall if I remember is 1800-2200 if I remember correctly.
Kameron YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY I'm a Middle ClASS HOLE 07.5 Dodge 3500 CTD -- Daily 73 C10 Factory BB SWB 2WD |
04-02-2010, 08:14 PM | #3 |
Also, most converter manufacturers can take your info and recommend a converter based on that.
If you contact Coan Converters (in Kokomo Indiana) they will ask for all the engine specs (displacement, cam, rear axle, anticipated usage, etc) and make whatever you want. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
04-03-2010, 06:54 AM | #4 |
Engine specs are as follows
355 V-8(.030 over 350) carter afb 650cfm carb edelbrock performer intake manifold comp cams high energy series duration @.050 212/lift.440'' 1 5/8 hedman headers,2 1/2 dual exhausts,cheapy turbo mufflers stock HEI,accel plug wires,ac delco plugs double roller timing chain cast iron heads with 1.94 intake/1.50 exhaust valves crank cut .010 arp connecting rod bolts lifter valley pan windage tray standard volume oil pump chrome dress up stuff(air cleaner w/4 inch open element filter,chrome valve covers,oroper pcv setup and chrome timing chain cover brass freeze plugs stock starter,alternator,water pump and master cylinder/brake booster going into a longbed truck that was originally a 250 I-6/3OTT with a 12 bolt rear with 3.73 gears unsure if it has a posi or not,will mostly be driven daily with the occasional drag race along with some light duty hauling and towing,truck has heavy duty suspension,truck is a 2 wheel drive hopefully that sheds better light into my inquiry.im also open to tips on ways to improve my engine as well so i can get the most out of its performance.bring on the opinions.
I'd rather push a Chevy than drive a Ford The Beast-1978 C10 LWB Red-1978 C10 LWB (Uncle Mike)Michael Henry Millett 11/5/1957 to 03/08/2012 Gone but will never be forgotten-RIP (Uncle Chuck)Charles Manning Gulbronsen Sr 1956-2012 Taken from us to soon but you will live on in our hearts-RIP Last edited by 1974ChevyC10; 04-03-2010 at 07:09 AM. Reason: forgot to add this |
04-03-2010, 09:11 PM | #5 |
haha, ford guys...
i wouldn't say >500 stall above stock.
04-03-2010, 09:27 PM | #6 |
so 2300-2700 stall speed is safe to go with taking into account my engine mods some of which may change im not sure yet on that one
04-03-2010, 10:12 PM | #7 |
Slugish
stock converter will be plenty good with the cam you have in there now . Too much stall will hurt you if you don,t need it .
04-03-2010, 10:29 PM | #8 |
thing is in orange crush-unknown gear ratio in rear,2wd,heavy half,31 10.50 tires on 15x8 rallys,stock suspension,longbed,no air,p/s and p/b and not much else weight or mod wise with the above mentioned 355 in it was a dog out of the hole.it would run high speeds ok but off the line was a joke.i think in ol red the engine with a tune up and maybe a few other mods will wake up nicely just trying to get an idea of the convertor i should go with and other mods i should make.
