04-02-2010, 11:58 PM | #1 |
Restoration Virgin!
Look at this Dimple....
Hey guys....
Quick question....I picked this 67 swb frame up about a year ago for FREE It seems the frame has a small dimple for the steering box but doesn't seem to be as deep as other PS frames I've seen.....Am I gonna need to dimple this a little more for the PS setup I'll use?? Thanks for looking and any help!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
04-03-2010, 01:14 AM | #2 |
What?
Re: Look at this Dimple....
Egads! Where did that frame come from? Pulled up from the bottom of the ocean?
To me it looks like the steering gear that is on there currently, may be the wrong one since there is no boss going to that spot? Either that, or it has corroded away while at the bottom of the ocean...
Chris 1968 K20 Suburban 1972 K10 LWB PU Last edited by vectorit; 04-03-2010 at 01:17 AM. |
04-03-2010, 01:46 AM | #3 |
I think the box is just loose and that bolt is missing. I think the earlier boxes that used the slave cylinder style power steering didn't have the dimple. There was a discussion a while back on that and the fix was either spacers or make your own dimple with a torch an a hammer. I'd vote for making my own dimple after I figured out how much space I needed.
04-03-2010, 02:14 AM | #4 |
Can't really tell from the pic, but it looks like it will need a little more "dimple" to work. Only way to know for 100% is to slap a new PS box on there
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
04-03-2010, 10:06 AM | #5 | |||
Restoration Virgin!
I don't want to use spacers!!!
04-03-2010, 12:12 PM | #6 |
Project Junkie! Fishing Poor!!
The early manual steering gears only had 3 mounting bolts, that is why there is one hole left open. As for the frame needing dimpled... It will definetly need that. I think that once you remove the old steering gear and clean the chassis you will see that it is not dimpled at all. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
04-03-2010, 01:37 PM | #7 | |
we're not spoiled we are just use to having the best for our trucks |
04-03-2010, 06:08 PM | #8 |
I just put in a 76' power steering box in my 67' C20. No frame alterations needed. I did need however trim away some of the radiator core support bracket and the driver side outer bumper bracket to fit. Works great!
04-03-2010, 06:16 PM | #9 |
Old Skool Club
I work with a guy who has a '67 that he bought new....w/o PS. Now that he is older, he's not got the same strength as he had so the installation of power steering got put on the front burner. We talked about the dimple factor. He said his frame had a dimple and he bought the steering box and all the other parts he would need off of a '72. Everything bolted up and it all works without modifications, according to him. He's happy.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
04-03-2010, 06:22 PM | #10 |
I changed from manual to power on my 67 1/2 ton without any modifications to the frame. I did have to trim the inner fender and bumper bracket a bit. The power steering box and hoses were from a 1986 chevy.
04-03-2010, 08:28 PM | #11 |
Hmmmmmm, I have owned 14 67 Chevys, and 6 67 GMCs. None of witch had the dimple in the frame. Including my 67 Panel. I have even seen a couple of 68s that didn't have them. The one in the picture above does not have the dimple. WES
04-03-2010, 09:53 PM | #12 |
I'm with Wes. I've never seen a 67 with the dimple. Also seen a few 68's w/o em. Not saying it's not possible, just never seen it in 40 plus years.
04-04-2010, 04:26 AM | #13 |
Here is a pic that might help. It's the only one I can find for now, but you can clearly see that the power steering box is attached to it the frame at the spot I think you are talking about. It's on a 67, but that's about all I know.
www.coolmoodart.com |
04-04-2010, 04:36 AM | #14 |
my 67 came from the factory with manual steering... and i had to Dimple the frame to get a newer power steering box to fit.... along with trimming the mount in front of the steering box
04-04-2010, 06:47 AM | #15 |
Wow every 67 frame I have and have had has no dimple where the steering gearbox attaches & several of our early 68's do not, are you all with 67 frames sure the frame is a 67? A 67 frame behind the motor mount runs straight back, 68 and up frame have a area that is cut away on inside edge to clear big blocks, so if your frame is all the same width on top behind drivers motor mount its a 67 if it dishes inward towards the outside of the frame its a 68 or later frame. Anyone looking to dimple the frame by heating and then beating with a hammer should use a extra steel plate on the inside of the frame to strengthen it where the bolts pass through the frame as when you heat it the metal loses strength and many end up a few years down the road with the metal tearing where the gearbox bolts to the frame due to the high stress found in this area.
GMCPaul |
