Old 04-06-2010, 09:27 PM   #1
Strut
Strut's Avatar
Copper Fuel Line??
Is it a bad idea to use copper hard line for fuel line?
1972 Chevy C10 SWB
1999 GMC Sonoma Mini
2008 Yamaha R1
2007 Harley Nightster
Strut is offline   Reply With Quote
Old 04-06-2010, 09:40 PM   #2
mrh33916
Project '67 454
mrh33916's Avatar
Re: Copper Fuel Line??
Interesting question, I'm curious to see what others may say.
I can tell you that some dual line feeds for Holleys are actually chrome plated copper tubing.
67 C-10 SWB Fleetside 454 (current project)
99 Crewcab SWB Dually 454
75 Datsun 280ZZ430
94 Formula 232LS 454
mrh33916 is offline   Reply With Quote
Old 04-06-2010, 09:45 PM   #3
Strut
Strut's Avatar
I have been working on a mobile home this week and just found out that copper line is not aloud with Natural Gas anymore.... It is no long up to code here cause over time the Natural Gas makes it brittle. That is what has brought up the question in my head....
1972 Chevy C10 SWB
2008 Yamaha R1
Old 04-06-2010, 10:12 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
It's a real bad idea. Copper work hardens from vibration quite quickly. Eventually it will crack. The FAA has long dis-allowed it's use on planes for good reason.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 04-06-2010, 11:03 PM   #5
ya it is a classic
so whats going on here????? i got copper in my 67 and my 55 gas lines. is that a problem or are you guys talking bout something else? sorry but im confused
ya it is a classic is offline   Reply With Quote
Old 04-06-2010, 11:21 PM   #6
70cst
70cst's Avatar
X2...if copper is a good idea then why hasn't the Auto makers used copper fuel lines in years past? Also in the aftermarket field...where can you purchase Copper fuel lines? Just some thoughts. Others???
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 04-07-2010, 01:17 AM   #7
chevy3100
Copper does work harden easily, which is bad (leads to cracking if not VERY secure). Also, copper is generally more expensive than steel.
chevy3100 is offline   Reply With Quote
Old 04-07-2010, 01:52 AM   #8
darthwall
I really don't see a reason not to use it it is more expensive than alot of other metals if the line is secured properly and not hanging in the frame rail rubbing on parts it should last a long time I have had trouble before with aluminium line rubbing and frexing. I built RV,s over here for 4 years and installed refers furnaces ovens generators and so on never had a customer come back about a gas leak
darthwall is offline   Reply With Quote
Old 04-07-2010, 02:04 AM   #9
70cst
70cst's Avatar
Like has been said...if copper metal were such a good idea than why have car mfg. never used copper fuel lines....non as far as I know. There are metalurgical concerns when using copper. By the way...what class of copper wouwld one use? Interesting thread.
Old 04-07-2010, 08:07 AM   #10
lakeroadster
Car manufacturers don't use copper because it is expensive compared to steel and because when using copper there is a Galvanic Reaction with other materials. Basically what this means is it will either be eaten away, or will eat away at dissimilar materials such as steel, aluminum, etc. Basically you want to pick materials that have a similar anodic index number. Check out this link http://www.engineersedge.com/galvanic_capatability.htm
Aluminized steel lines are easy to work with and are readily available. Note how on the anodic indes chart aluminum and steel are very close and are therefore compatible.
I hope this helps.
I hope this helps.
lakeroadster is offline   Reply With Quote
Old 04-07-2010, 02:35 AM   #11
darthwall
my bad I thought the question was about brass got my mine mixed up there
Old 04-07-2010, 07:39 AM   #12
cdowns
cdowns's Avatar
quite a few cars in the 20's and 30's had copper fuel lines a few even had copper brake lines // turned out they didnt work so well
Old 04-07-2010, 10:37 PM   #13
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
very bad idea... unless you like fuel leaks
Old 04-07-2010, 11:07 PM   #14
LockDoc
The Older Generation
LockDoc's Avatar
OK, I'm not saying this is a good idea but I am saying it works. When I originally built my '36 Ford Coupe I didn't have any of the fancy smancy tools like a tube flaring set or tubing benders so I took the easy way out and used 1/4" copper tubing with compression fittings. I am in the process of re-building the Coupe right now and I replaced the copper with steel fuel line. When did I originally build the Coupe you say?... It was the winter of 1961/62, 48 years ago. I was 20 years old. When I removed the copper line last fall I straightened it out with no problems. No cracks, no corrosion, & not brittle, and it is laying out by the shop if anyone wants to inspect it. I had two, maybe three clamps on it holding it to the frame. Maybe the newer copper isn't the same quality as the old stuff, I don't know. They have cheapened up everything else...
LockDoc
Leon
