Old 04-07-2010, 04:29 PM   #1
bobcostas
bobcostas's Avatar
Where's the washer fluid reservoir
Hey guys.
i was just nosing around in my truck, replaced the wipers, and noticed the two tubes running to the washer nozzles, and followed them to the wiper motor. is there supposed to be a washer fluid reservoir under the dash?
thanks dudes
'64 Corvair Ragtop
'66 C10 Stepside
"The oxen may be slow, but the Earth is patient"
bobcostas is offline   Reply With Quote
Old 04-07-2010, 04:47 PM   #2
Bugeyev8
Bugeyev8's Avatar
Re: Where's the washer fluid reservoir
should have a plastic tank inder the hood
Bugeyev8 is offline   Reply With Quote
Old 04-07-2010, 04:48 PM   #3
daverod
SSN 706
daverod's Avatar
Maybe 1/2 and 1/2 with rad. overflow?
daverod is offline   Reply With Quote
Old 04-07-2010, 05:34 PM   #4
bobcostas
bobcostas's Avatar
haha. My rad overflow is a old prestone jug. i think it came with the LX package in '66.
alright. so in the case i had a washer fluid bottle, where would the hose run? to the same zone as the two tubes going to the nozzles?
'64 Corvair Ragtop
'66 C10 Stepside
Old 04-07-2010, 06:19 PM   #5
63sbssbbw
UCA63
63sbssbbw's Avatar
it's on the inside of the radiator support,drivers side next to the rad
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 04-09-2010, 04:26 PM   #6
bobcostas
bobcostas's Avatar
Thanks guys. its totally not there. im going to try and trace the route the hose went and make a new one.
'64 Corvair Ragtop
'66 C10 Stepside
Old 04-09-2010, 05:22 PM   #7
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Could also be mounted drivers side of the master cylinder.
Old 04-09-2010, 05:53 PM   #8
ChevySixty6
ChevySixty6's Avatar
I'd just go up to the gallery area and look around at the engine pics. You'll find both locations for the resevoir. I've only had two '66 trucks and they were both on the radiator mount right over the horn relay. Several mfgs. have the bracket and jug that fits it. Although some of the brackets aren't made to fit over the relay. I got that info from Lilred66. He sold me the correct one.
Happy hunting.
Members i've met: LiLRed66
ChevySixty6 is offline   Reply With Quote
Old 04-09-2010, 08:27 PM   #9
DPowers
One foot in front of the other
DPowers's Avatar
I might have an extra bracket and reservoir if you need it.
DPowers is offline   Reply With Quote
Old 04-10-2010, 09:44 AM   #10
LILRED66
LILRED66's Avatar
Maybe these will help.
LILRED66 is offline   Reply With Quote
