Old 04-07-2010, 11:35 PM   #1
carlp
straight 6 in v8 mounting spot
is it at all possible that some could make an inline six fit in the 8 cylinder motor mount area? my truck had a straight six when i bought it, but the motor towers are bolted to the forward most set of bolt holes and the fan is 1/2" to 1" away from the radiator.
also according to my vin the truck was originally an 8 cylinder. it also sounds as if the transmission is not actually bolted to its crossmember and just rests on it.
i can post a picture of the motor if that helps at all.
i have got everything to put in a 350 and TCI th350 other than the motor towers and tranny crossmember, dont want to buy new ones of those if i dont have to. this truck is just my driver/beater.
thanks for your help.
carlp is offline   Reply With Quote
Old 04-07-2010, 11:42 PM   #2
carlp
Re: straight 6 in v8 mounting spot
also after looking at a bunch of photos of straight 6 trucks my motor is missing the spacer between the fan and pulley. and it is still a finger's width away from the radiator.
Old 04-08-2010, 01:07 AM   #3
realsteelGM
realsteelGM's Avatar
Smile Re: straight 6 in v8 mounting spot
I know exactly what your talking about, I am in the process of pulling my 292 inline 6 and sinking in a 283 v8 which was originally the stock motor for my 67 truck. If your going to keep the inline 6 in it you should move the mounts back and shorten up the drive shaft. The transmission cross member also needs to be moved back.
"gotta love something that works without a computer"
realsteelGM is offline   Reply With Quote
Old 04-08-2010, 06:36 AM   #4
carlp
thanks, thats what i thought.
i dont want to keep the straight six/manual.
ive got a pretty strong '69 marine 350 with bow tie phase II heads and a tunnel ram. backed up with a reverse manual th350 with 3500 converter.
i just didn't want to buy a tranny crossmember or new motor towers if i didn't have to.
thanks,
carl
Old 04-08-2010, 07:15 AM   #5
truckdude239
truckdude239's Avatar
my transmission on mmy n 71 bolts tot teh bell housing and thats it just hangs there and its a v8
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
