Rear End Help
I found a rear end that may be quicker than the Eaton I have with 4:10 gears. I have a 67 C20 2WD LWB with a 3 on the tree and a 350. I want to put a TH350 and a faster rear end./ Can anyone identify if this is a Dana rear end? What gears were stock with this...its a 1970 GMC C20 that was a 4 speed manual.
If your not living for something, your dieing for nothing... |
Truck and auto performance nut
Re: Rear End Help
its a Dana...you have to look for the "44" or "60" on it to tell the difference.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
Re: Rear End Help
Where would I find the 44 or the 60 and what is the difference between them? Thanks in advance.
No takers? LOL
Or is my question really common knowledge and I should feel shame for asking?
If your not living for something, your dieing for nothing... Last edited by eastcoastcivil; 04-09-2010 at 02:04 PM. Reason: more info |
Re: Rear End Help
I'm with you on this one. Is there any source for Rear End info. on our trucks? Al W.
Re: Rear End Help
A Dana axle has the model number displayed as a raised numbering on the casting. From the rear it would be bottom right of the rear cover, on the casing. On the front, its to the right of the pinion shaft.
#7 | ||
Re: Rear End Help
These are totally opposite things. "Quicker" is standing start acceleration, which is a lower gear. Low gears accelerate quickly, but you run out of top end speed because of the increased RPM. "Faster" is higher top speed, which requires a higher gear. High gears litterally translate into higher top speed at the same engine RPM.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
-Chris
![]() Join Date: Sep 2002
Re: Rear End Help
Re: Rear End Help
that looks like a dana 60 to me and it would be a stronger diff than a 12 bolt diff
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
Re: Rear End Help
did you ever stop to think that maybe more horsepower will solve the problem?? a 411 is a nice rear but at probally less than 150horsepower to the rear wheels there just not much any rear is going to do for you
Re: Rear End Help
ok...I have a 350 bored out so power is not the problem...I have 4:10 which means I have great power at the start (quicker I guess)...but I want to make the top end better so I am not screaming at 3000 RPM cruising down the highway at 50 MPH. lol
I live on a road that has a 60 MPH speed limit at the end of my driveway.
Re: Rear End Help
Here is a picture from my gallery. Look for a 60 or a 44 here. The D60 had 3.54, 3.73, and 4.10 gears. Possibly lower, but I doubt it. The after market should have more possibilities.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
#13 | |
Big Red - Now its a SWB!
Re: Rear End Help
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's Last edited by Jacfourteen; 04-10-2010 at 01:37 AM. |
its all about the +6 inches
Re: Rear End Help
the dana 60 in the 3/4 tons is not very strong, they are known for shattering the axle shafts... esp in 4x4 aplications
#15 | |
Re: Rear End Help
I ask because a Dana 60 was what I had planned on upgrading to when my new LSx motor gets installed... and a set of drag radials breaks the current 12 bolt. ![]()
#16 |
Re: Rear End Help
www.bowtieoverdrives.com
Keep the 4.10's and go with a 700R4 or 2004R instead of a turbo 350. IMO adding another gear is way more practical for increasing top speed... Because no one wants it to take 2 hours to get to that top speed. Unless you're looking for a much higher top speed in which case you should do overdrive and swap gears out. |
#17 |
Re: Rear End Help
I have but would be doing the work myself and would not know how to wire a 700R4 I guess. I was told a short tail TH350 woould be a direct swap without having to modify my axle since I now have a 3 speed Saginaw. I thought it would be easiest.
Would the 2004R be easier to set up than the 700R4?
If your not living for something, your dieing for nothing... Last edited by eastcoastcivil; 04-09-2010 at 09:02 PM. Reason: more questions |
#18 | |
Re: Rear End Help
#19 |
Re: Rear End Help
i am putting in a 4.10 in my 72 burb c20 w/ ho52 (has 4.57 now) and plan to add the factory 65-69 borg warner overdrive to the 3 on the tree (replaces the tail shaft). that will give me a decent rear gear but give a better ratio on the highway than a straight 3.08. you can't beat a 3.73/4.10 with a good overdrive. the 200-4r is a direct swap for the turbo 350, whereas the 700 is longer than either auto or the 3OT and will require the driveshaft be shortened. i also suggest a lockup converter to reduce excess heat in the trans and save every last engine rev you can (advantages normally reserved for manual transmissions). all in all its a clean install.
#20 |
Re: Rear End Help
that doesn't look like my 200-4r
#21 |
Re: Rear End Help
So I went back to see the guy who sold me the 700R and swaped with him for a rebuilt 200-4R which has been rebuilt with a shift kit installed. Shouold be just what I am looking for with my C20.
#22 |
Re: Rear End Help
Just make sure you get that T.V. set up correctly before you ever move the truck or you'll ruin the transmission. It's critical.
#23 |
Re: Rear End Help
glad to hear you're going with an additional gear.
www.bowtieoverdrives.com all the wiring info and parts you need right here. I believe you can do some of the wiring without ordering their kits but if you are like me and like to play it safe (not electrically savvy) you may just wanna order right from them. Last edited by davebloomer; 04-12-2010 at 01:18 PM. |
