This chevy truck axle is a good replace for my blazer rear axle?
Hi, I have a 1973 GMC Jimmy 4x4 for a restore project, but, the rear axle is not the original, (the old owner replaced the axle with another model with 5 nuts in the wheel) now I want to replace this with another axle, because I want to activate the 4x4 option in the blazer, after some search here, I found a chevrolet truck, it's for sale, I want to know if I can use the rear axle, I want to know if this axle is the same model of the blazer o GMC jimmy 1973
here is the truck... (all I know is: this is a 69 truck, 2WD, L6 250 engine, suspension: front coils rear leaf)
------------------------------------ 1988 Ford taurus LX SW V6 3.0L vulcan - Axod 1973 GMC Jimmy Sierra 4x4 ![]() L6 diesel nissan LD28 (temporal engine) |
more ideas than money
Re: This chevy truck axle is a good replace for my blazer rear axle?
It is hard to tell from the pictures, but I think it will swap over. As long as it is going leaf spring to leaf spring you may need to move the spring perches.
Please remember that you need to make the gears match front/back, otherwise bad things happen!
![]() 1948 Chevy 3100 5 window 1966 Chevy C30 Dually 1967 Chevy K10 1972 Chevy K20 1972 Chevy C10 1972 Chevy K5 Blazer 1987 Chevy V10 2003 Chevy Suburban |
Are you trying to go from "5 nuts" to "6 nuts"?
I think that green 2x4 might be a 5 Nutter? ![]() ![]()
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
Chevys Kick A$$
Yea x2 that's exactly what I was thinking. Need to find a 4x4 with the 6lug set up! Don't forget to match the gears like stated above.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
my GMC original axle is 6 nuts (4wd) this chevy truck have 6 nuts but is 2wd
------------------------------------ 1988 Ford taurus LX SW V6 3.0L vulcan - Axod 1973 GMC Jimmy Sierra 4x4 ![]() L6 diesel nissan LD28 (temporal engine) Last edited by masaki; 04-09-2010 at 04:32 PM. |
