Old 04-09-2010, 11:52 PM   #1
kwmech
straight axle
Truck in question. 1969 GMC 1 ton (ex motorhome class b). The front end is getting quite sloppy. thinking about the amount of work involved with spring replacement, x shafts, ball joints, tie rods, center link, disc brake conversion etc. Pondering converting to a straight axle. This would entail basically a Dana 60 front axle without the differential center section. Converting to leaf spring. and going with a spring under to keep the truck at a reasonable height to keep the flat bed workable. Building, fabrication and converting is not a problem as I have the skills to complete. Any suggestions or thoughts?
Old 04-10-2010, 01:00 AM   #2
tecky11
Re: straight axle
I havw a few questions for you, 1. is this an 8 on 6.5 bolt pattern? 2. find a Ford F450 or smilar style Chevy, Dodge truck with a kingPin style axle, ALL will have leaf springs. this will make the ride ruff, but eadier to maintain
tecky11 is offline   Reply With Quote
Old 04-10-2010, 11:00 AM   #3
kwmech
Re: straight axle
Yeah, standard 8 lug. I'm currently looking into the super duty stuff and getting some measurements
Old 04-10-2010, 12:55 PM   #4
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Re: straight axle
I have a magazine article here where a guy did that conversion only he used Dana 44 knuckles. He was gaining clearance for a Detroit 4-53. The trucks stance wasnt bad...I would think going spring under might set you to low.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 04-10-2010, 01:24 PM   #5
CE20934
CE20934's Avatar
Location: Help! I'm in an office park with its own network of freeways!
Re: straight axle
The mid-'90s C3500HD chassis has a kingpin straight axle too.
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man)
'95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis)
'07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed*
CE20934 is offline   Reply With Quote
Old 04-10-2010, 02:08 PM   #6
kwmech
Re: straight axle
Gonna have to check that out for fit and WMS
Old 04-10-2010, 10:23 PM   #7
Dark Knight
Dark Knight's Avatar
Re: straight axle
Why not just use an I-beam axle? There's probably a company that sells them already modified with disc brakes for the older Chevy's.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS
-1983 Chevy Silverado C1500- 383 stroker, TH400
-1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears
-And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket
"The only thing we have to fear is fear itself." -FDR (and maybe rust too)
You've gotta be able to stop and steer before you can go fast!
Dark Knight is offline   Reply With Quote
Old 04-10-2010, 01:04 AM   #8
63chevyll
gets board easy.......
63chevyll's Avatar
Re: straight axle
yeah,
sounds like a lot of work.
How ever do you find the time to perform that conversion
63chevyll is offline   Reply With Quote
Old 04-10-2010, 10:59 AM   #9
kwmech
Re: straight axle
Originally Posted by 63chevyll View Post
yeah,
Not much different that converting to 4wd, just eliminating the diff and the t-case. I'm also looking at the time and expense of tearing the complete front end down and rebuilding it. That also is a full days work and then some with the disc conversion
Old 04-10-2010, 01:06 PM   #10
addicted2dunes
Insane In The Membrane
addicted2dunes's Avatar
Re: straight axle
Why not just run a straight axle tube? Like the 2wd Ford F450-550's. It's the same as a front differential minus the actual differential part. Just has a tube going from left to right. Still solid axle but doesn't have all the diff guts.
Cameron Gunlock
Project: ALTER-K-TION ('57 GMC Quad Cab) http://67-72chevytrucks.com/vboard/s...d.php?t=393750
addicted2dunes is offline   Reply With Quote
Old 04-10-2010, 02:07 PM   #11
kwmech
Re: straight axle
That's exactly what I was thinking of building with Dana 60 stuff. I will gain a much larger wheel bearing and still retain the same disc brakes and calipers as factory uses on the '71 +
