Old 04-11-2010, 10:38 PM   #1
jake wells
Arrow might be buying a 64 C40
Anything to look for on one of these. it runs and drives fine i have no ideal what kind of 6 cylinder it is. its only 650$ the only thing about is the brakes are a little weak. any pointers to this truck?
thanks jake
jake wells is offline   Reply With Quote
Old 04-12-2010, 12:42 AM   #2
Captainfab
60-66 Nut
Re: might be buying a 64 C40
The engine is probably a 250 since it is a C40. The drivetrain in the C40's aren't much different than the C10-30's. The running gear and suspension is where the difference is. Does it have a 2 speed rear end? Trucks like these don't ride very well without a bit of weight on them, and they are low geared so freeway driving isn't going to be at 65. Bodywise they are mostly the same as the C10-30's except for the fenders, grill, grill panel, radiator support. The cabs are the same except for the floor and the lower firewall in the trans area.
Old 04-12-2010, 05:53 AM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
You have to pressure bleed the brake system. You cannot bleed the system any other way. We made a pressure system out of pipe and fittings. If you know of someone who has a pressure bleeder then it's easy.
Old 04-12-2010, 08:20 AM   #4
jake wells
no it doesn't have the 2 speed rear. but it does have a good amount of cab rust on it somebody painted it with a roller so it doesn't look bad
Old 04-12-2010, 08:54 AM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
Whether it's a good deal or not really depends on what you would do with it. Rust repairs are the most expensive part of restoration unless you can do it all yourself. If its simply going to be used as a yard truck this may not matter. Here's a thread that might help in making an informed decision:
http://www.stovebolt.com/techtips/bu...uide_60_66.htm
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
