tach question
OK....my tach is way off according to the computer.
I'm thinking a tach is either good or bad, but maybe there is something I don't know? Can a tach be hooked up incorrectly and still give a reading? It reads quite a bit higher RPM than I am doing. So.....if I have to replace it I've read about a Camaro tach swap. What year Camaro tach swaps without any customization? If I have to change tachs, I might as well get one that reads higher than 5,000 rpm.
1972 Blazer - Bronco Orange - In the werks http://67-72chevytrucks.com/vboard/s...d.php?t=323444 1991 F250 - Hunting truck w/ Detroit rear locker, ARB front locker, front and rear winches .... and more.... 1997 Grand Cherokee - fun jeep - Detroit rear locker, ARB front locker, front winch, 411 gears, lots of lights ;-) 2004 Hot Rod DuraMax - Dnyo'd at the wheels with 525 HP and 1100 lbs torque.....mustang killer. |
SKINNY TIRES RULE!
Re: tach question
Is the tach factory, new, used, etc. Is it possible you have a 6cyl tach?
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Re: tach question
It's a used tach I got from a member here and it's an 8 cylinder tach.
It's just not reading right and I'm pretty sure it's hooked up properly. It's a brand new Painless harness and those are pretty hard to mess up.
Re: tach question
You might check your dwell. I've had my tach go a little crazy when my points were bad.
Re: tach question
original tach might be off... I like the original look myself but you could do the camaro or an aftermarket tach...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
Re: tach question
They do tend to act funny with age. There are services that restore factory tachs. I've done this before on muscle cars. I do like the factory look, but the tachs for these trucks stop at 5,000 rpms which does me no good.
I thought about checking into the service to see if they can recalibrate the tach with a new face and higher rpms just to keep that factory look. Until then I just run aftermarket. Something to think about. |
Re: tach question
I'd rather have a tach that reads higher RPM's as long as it looks like it belongs in the cluster.
In this thread Sicmaro has what I'm looking for. http://67-72chevytrucks.com/vboard/s...ht=camaro+tach Has anyone used a different year Camaro tach? This 72 tach looks like it fit pretty good.
Re: tach question
Well I guess it depends on what everyones idea of what "looks like it belongs" is.
To me that means the factory tach. Which is why I'm sending mine out to have it refaced in original faunts for a higher reading and then recalibrated. It's expensive to do, but it will look correct when it's done. Most people probably won't even notice the rpm change on the face. Until then I just mount an aftermarket on the column, old school style ![]() |
Wide n'Low
![]() Join Date: Jan 2007
Re: tach question
I know there is a new 8000 rpm replacement tach available now, but forget the price. I saw it in the new truck shop catalog.. I also saw one at DC Trucks this week, and it looks nice.. I want one...
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
One of the First
![]() Join Date: Jan 2000
Re: tach question
If your running a HEI it will read a little higher, you can send off to a decent instrument repair shop and they can make the necessary corrections. I run a Petronix distributer/coil and it sparks just fine and the Factory tach is dead on.
