Always a work in progress
Adjusting shift indicator
I have an 85 with th350 and on the column it has the correct 3 spd indicator but for some reason it is off. When I am in regular drive(D) it is pointing to neutral. Is there some way to adjust the indicator or linkage?
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
Re: Adjusting shift indicator
Yes - it has a little "edge clip" that clips to the side of the steering column bowl. You can scooot that clip one way or the other to adjust.
Incidently, we do that with the trans in neutral. Put the shift lever in Neutral and move the needle to "N"; that way you are more accurate in the middle and any error is moved to the ends of the travel (to L, which you don't use often, and to P, which is pretty robust). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
One shot, one kill.
Also note, I would check the shift linkage under the truck where the goes from the trans to the frame. At the frame end there should be a teflon button with a spring behind it. The springs are noted to rust away leaving the linkage sloopy. The button will last forever. If you find this, remove the linkage and put a new spring in and adjust the linkage. Make sure trans is in neutral, make sure gearshift is in the neutral "gate", then tighten the linkage back up again. After that do what Keith said to do and you'll be good to go. Grease everything up good. Jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shot ![]() |
There isn't a spring or button to my knowledge, so I will look into getting one.
#5 | |
