Old 04-16-2010, 11:39 AM   #1
BarryB
BarryB's Avatar
Need Advice on making stainless brakelines
I'm not sure where to put this question, so I posted it here. Where can i get pieces of stainless tubing without getting it in set lengths from the parts store? I was told you could buy it in rolls but how would you straighten it out. Now I know there are kits you can buy, but I want to make my own , just because I want the experience.
I have also been told before that stainless couldn't be flared to the standard 45* flare, is this true? I am aware of it needing to be doubled flared also.
So hoping for some tips and possible sources.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 04-16-2010, 12:49 PM   #2
cdowns
cdowns's Avatar
Re: Need Advice on making stainless brakelines
i believe to flare stainless properly you'll need a hyrdyolic flaring tool for a few hundred bucks
Old 04-16-2010, 04:36 PM   #3
LMDGUY
LMDGUY's Avatar
some companys rent the tool.. I will look when I get home.
1973 C10 "Chain Reaction"
Street Trucks cover Feb 2012
2013 Silverado
1964 Cadillac
LMDGUY is offline   Reply With Quote
Old 04-17-2010, 01:18 AM   #4
mickeymouse
Buy the tubing from Summit.
http://www.summitracing.com/parts/SUM-220214/
It's annealed, so it will flare easily. You have to keep the flare "vice" tight.
I also use stainless brake fittings.
To unroll it, you bend it against the ground and straighten as needed.
mickeymouse is offline   Reply With Quote
Old 04-17-2010, 02:50 AM   #5
oldspowered67C10
I bought my tube from McMasterCarr, its not cheap but its straight and comes in varoius lengths. I used a flaring tool from Rigid but I used AN fittings so it was 37 degree tool.
oldspowered67C10 is offline   Reply With Quote
Old 04-17-2010, 08:00 PM   #6
mbgmike
Thats about double our price
mbgmike is offline   Reply With Quote
Old 04-17-2010, 09:49 PM   #7
mickeymouse
I wish your website were more usable then. Can't find it there.
Old 04-18-2010, 11:01 AM   #8
mbgmike
Not listed yet. It takes forever to list everything we sell
Old 04-17-2010, 11:04 PM   #9
8mpg
8mpg's Avatar
Are you guys coming up for Pate? Hoping to pick up some stuff like brake lines without paying big shipping.
8mpg is offline   Reply With Quote
Old 04-18-2010, 11:02 AM   #10
mbgmike
We are trying to get their but may not make it. Our shipping usually is not too high
Old 04-18-2010, 01:42 PM   #11
texastrendz
hey mike, i am installing a front dropmember in my 72 c-10. I am keeping with the stock braking system. What size lines do you recommend for a stock system. I am wanting a line that does no require a hydraulic style flaring tool, but stainless would be nice. i would like to pick it up from you since you are just down the road. thanks daniel. p.s. it is a disc/drum setup
texastrendz is offline   Reply With Quote
Old 04-17-2010, 12:45 PM   #12
8mpg
8mpg's Avatar
I have never had luck with the Rigid flaring tool on stainless. To do it correctly, Id use a hacksaw to cut it. The regular cutting tool pinches the stainless and give is a chamfer. If you do try it, make sure you get a good reamer. This will straighten out the end and help it flare.
Hydraulic is the way to go if you can find someone with one.
Best bet is just to buy prebent ones.
THey also make tube straighteners...this is a nice one..they make cheaper ones:
Old 04-17-2010, 06:32 PM   #13
mickeymouse
I have no problems flaring the line I posted. Take your time and do it right. No issues at all.
Old 04-17-2010, 07:58 PM   #14
mbgmike
We sell the tubing in just about any length. fall the fittings to. Or any Brakquip dealer has them. You can use annealed stainless and it flares and bends easier than the stainless used in most kits.It DOY approved also. I prefer to bend them unless on a stove stock truck.
Old 04-22-2010, 02:27 AM   #15
mclairmo
I know this was not part of the original question, but I read that stainless steel is harder than regular steel and as such, stainless does not conform (or mold itself) to the sealing surface as well when bolted up and is more likely to leak, which is one reason the oem does not use stainless for brake lines. This is why I have always stayed away from stainless brake lines.
mclairmo is offline   Reply With Quote
Old 04-22-2010, 04:20 AM   #16
oldspowered67C10
3/16 is pretty typical for brake lines.
