Old 04-17-2010, 05:02 PM   #1
Rede
4spd - turbo400 ?'s
I've started collecting parts before doing any work as I don't want to get part way through and realize that I've forgot about something along the way.
My check list includes:
turbo400 out of a 4x4 (rebuilt with converter)
np208 adaptor for my rebuilt tcase
I've priced out a flexplate (steel, 168tooth) @ 122 bucks
and I was told I could either bend my own trany lines or use hydrolic hose(?!)
the truck has an automatic colomn already but the floor shifter sounds much easier.
Are the front a rear driveshafts the same length for both trucks or is this going to be another hidden expense?
Anything else I'm missing or budget suggestions on floor shifter options??
Truck is an 81 3/4 ton with 9.5" semi floating rear and I was told a spicer 10 bolt upfront.
Rede is offline   Reply With Quote
Old 04-17-2010, 07:50 PM   #2
Mike C
Mike C's Avatar
Re: 4spd - turbo400 ?'s
You are swapping from an SM465? Driveshafts will be different. Is the 465 a bolt on yoke or slip? Somewhere around that time they changed. My 86 205 had the slip yoke rear and it MIGHT have interchanged with the TH400/208. I have that setup in a parts sub, but never compared. The 400 a LOT longer than the 465 so front is probably longer. But your tape measure will confirm.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
