Old 04-20-2010, 01:28 PM   #1
Kel's 72 GMC
GM made with FORD paint
Kel's 72 GMC's Avatar
Exclamation Can somebody ID my rear differential on my 72 GMC 1500?
im guessing the model numer is GM 58
i think the other number reads 3896838 or 3896839
1972 GMC Custom 1500, 2WD LWB, 1970 chevy impala SS 350 c.i., shaved door handles, Ford Paint (portofino blue), blue underglow, and much more.
1998 GMC Sierra 1500 ext. cab, 2WD SWB, 305 c.i. all original 165,000 miles and still strong (daily driver)
Kel's 72 GMC is offline   Reply With Quote
Old 04-20-2010, 01:29 PM   #2
Kel's 72 GMC
Re: Can somebody ID my rear differential on my 72 GMC 1500?
more pics
Old 04-20-2010, 01:42 PM   #3
JimmyFloyd
Looks like a GM 12 bolt rear
To figure out if it is Posi, jack it up so both rear wheels are up and spin the tire. if the other side moves the same direction, posi, if opposite, then it's open.
To get the gear ratio, put a mark on the tire and one on the drive shaft. Spin the tire and count how many times the drive shaft turns during 2 full turns of the tire. You can use those numbers to figure out the ratio.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 04-20-2010, 05:03 PM   #4
Kel's 72 GMC
its not a posi. Do you know what the numbers mean? So its just a GM 12 bolt not a DANA or any other brand
Old 04-20-2010, 05:07 PM   #5
JimmyFloyd
Correct. GM 12 bolt.
http://coloradok5.com/axleguide.shtml
Old 04-20-2010, 07:34 PM   #6
Kel's 72 GMC
is there a good site that has any info on the casting numbers for a GM 12 bolt for trucks. All ive found where for Camaros and Chevelles. Also any idea on the ratio?
Old 04-20-2010, 08:58 PM   #7
Sublvr72
Sublvr72's Avatar
appears to be a standard GM 12 bolt as others have said. You probably won't know the ratio unless the service tag is still on the diff, which it appears that it's long gone. You can take the cover off and count the teeth on the pinion and gear to figure it out if you really want to know.
Sublvr72 is offline   Reply With Quote
Old 04-20-2010, 11:33 PM   #8
gkesseru
gkesseru's Avatar
I find it easier and accurate to make a mark (via masking tape and magic marker) on rear yoke and diff housing. I put a piece of masking tape around the entire tire and make a start mark using a chair or something to point to the start mark on the tire. Turn the wheel until the drive shaft makes exactly one turn. Make a second mark on the tire masking tape for the distance the tire traveled. Cut off the tire masking tape exactly at the start mark. Lay the tape straight and measure the tire circumference (whole tape) and divide by distance tire moved (second mark). Multiply by two. That's the ratio. Don't multiply if you have posi.
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 04-21-2010, 08:32 AM   #9
neba
open the cover. the gear lube should be changed. then you can see what you have.
neba is offline   Reply With Quote
