04-20-2010, 02:14 PM | #1 |
Humvee wheels (Any Pics?) 73-87
Ive looked all over the the search and cant find a thread with any pictures of humvee wheels on a 73-87? Anyone have any? Offset might be odd but I can always wheel space them.. Thanks
04-20-2010, 02:18 PM | #2 |
Re: Humvee wheels (Any Pics?) 73-87
Are you talking about H2 wheels or H1?
1981 K5 Blazer 2WD Silverado package.(sold) 1981 C-10 Short bed Stepside 1984 Monte Carlo SS TPI 350 1986 Monte Carlo SS T-Top 355 Carb 1994 Cadillac Fleetwood (sold) 2006 Silverado SS Silver Birch RWD LQ9 |
04-20-2010, 02:25 PM | #3 |
Neither.. Military humvee steel beadlocks.
04-20-2010, 02:40 PM | #4 |
Military HMMWV wheels do not have beadlocks. They are only a steel two piece wheel. The face of the wheels is sealed with a large O-ring. Most are destroyed before being discarded. I personally have destroyed dozens. I am a ten year Air Force Vehicle mechanic. I work on HMMWV's everyday. I would just go for the same look in the aftermarket. I wouldnt even consider using a wheel adapter on a off road vehicle either.
04-20-2010, 05:31 PM | #5 |
Sure they do, if the run flat is retained. Either the rubber run flat and insert, or the magnesium run flat itself.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
04-20-2010, 11:11 PM | #6 |
You know the difference between a bead lock and a run flat right? It sandwiches and locks the bead of the tire on the rim. The run flat does not lock the bead it only allows driving after you already have a flat tire and only at very low speeds for limited time. The mag run flat is also known to heat up and cause fires when the grease packs on them arent serviced regularly. They discontinued those years back when they quit using Bias ply tires. They are much easier to change out than the rubber run flats. Only 8 bolts/ two pieces and it's out. I will take a few pics from work in a little while.
1981 K5 Blazer 2WD Silverado package.(sold) 1981 C-10 Short bed Stepside 1984 Monte Carlo SS TPI 350 1986 Monte Carlo SS T-Top 355 Carb 1994 Cadillac Fleetwood (sold) 2006 Silverado SS Silver Birch RWD LQ9 Last edited by 81BLAZE; 04-20-2010 at 11:33 PM. |
04-21-2010, 11:31 AM | #7 |
You guys are the best! Thanks for the pictures! That helps alot. I'm wondering if they are using wheel spacers...?
04-21-2010, 02:37 PM | #8 | |
By the way on page 201 of the HMMWV operating manual (TM 9-2320-280-10) it advises to air down the front tires to 12psi and rear to 16psi in sandy conditions. On a vehicle as heavy as a HMMWV do you think they would advise to air down without a some type of bead lock? Also if there were not beadlock, when the tire did go flat and the vehicle ran on the run flat the beads would come off and potentially get stuck. Oh and 1 more thing, due to the small outer lip where the tire bead sits a beadlock is required to hold the tire on when running low pressures (ie. Sand as recommended by the -10). Oh and by the way I was a mechanic in the Army for 8 years so I am not just pulling this crap out of my butt.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call Last edited by Prerunner1982; 04-21-2010 at 02:56 PM. |
04-20-2010, 02:57 PM | #9 |
I have a 1989 humvee with these wheels on it, but its getting a duramax conversion out of the state and I cant get to the wheels. The wheels are very easy to find. Anyone with pictures?
04-20-2010, 03:44 PM | #10 |
Resident of Here
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
04-20-2010, 04:01 PM | #11 |
There is no military humvee wheels on any of those trucks... Anyone else?
04-20-2010, 05:24 PM | #12 |
Obviously these are all military trucks, but may try ColoradoK5.com for more. You would need wheel spacers for the stock axles unless you use dually axles for which the stock hmmwv wheels should fit with no problem. To run them on regular axles they are typically re-centered with the correct offset.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call Last edited by Prerunner1982; 04-20-2010 at 05:33 PM. |
04-20-2010, 05:39 PM | #13 |
04-20-2010, 05:41 PM | #14 |
04-21-2010, 11:35 AM | #16 |
It'd be alot cooler if you did
These wheels look awesome!
04-21-2010, 08:15 PM | #17 |
Twitchin...good looking truck! Any mods to the front to run that size tire?
04-21-2010, 08:25 PM | #18 |
the a-arms are at full extension via airbags. so about a 2 to 3 inch lift in the front. and i had to trim just under an inch off the bottom on the front fender.
04-21-2010, 08:49 PM | #19 |
Kid's Mechanic
Is this anything like what you gentleman are talking about??
http://www.staunproducts.com/beadlock.php |
04-22-2010, 09:13 AM | #20 | |
04-22-2010, 10:37 AM | #21 |
So what center wheel spacing will I need?
http://www.trailworthyfab.com/124-Do...l-Special.html |
